Add High Speed Wireless N Connectivity to a Desktop or Laptop Computer through USB. The USB150WN1X1 USB 802.11N Mini Wireless Network Adapter allows almost any USB-enabled desktop, laptop or netbook computer system to connect to 'n', 'g' or 'b' wireless networks. Using a 1T1R (1 Transmitter/1 Receiver) design over the 2.4GHz frequency in an extremely compact form factor, the USB adapter is capable of reaching up to 150Mbps over an 802.11n network while taking up minimal space.
Backward compatible with 802.11b/g networks (11/54Mbps), this adapter is a versatile wireless networking solution.
- StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R (USB150WN1X1) - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 1.9 cm x 3.5 cm x 0.6 cm
- 4 g
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 150 Mbps
- Frequency Band
- 2.4 GHz
- Processor
- Realtek Semiconductor RTL8188CUS
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Black
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.5 - 10.14
- 2-year warranty
- Designed For
- P/N: R150WN1X1T
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- 150 Mbps
- Frequency Band
- 2.4 GHz
- Max Range Indoors
- 100 m
- Max Range Open Space
- 300 m
- Full duplex mode, QoS, Ad-Hoc Mode, WPS
Aerial
- Antenna
- Internal
- Antenna Qty
- 1
Processor / Memory
- Processor
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA
- Black
- Software Included
- Drivers & Utilities
- OS Required
- 1.9 cm
- 3.5 cm
- 0.6 cm
- 4 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90%
- Designed For
- P/N: R150WN1X1T
StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R | In Stock | £13.16 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter | In Stock | £23.36 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - White | In Stock | £20.71 |
StarTech.com USB 2.0 300 Mbps Mini Wireless-N Network Adapter - 802.11n 2T2R WiFi Adapter | In Stock | £15.40 |
StarTech.com USB 2.0 AC600 Mini Dual Band Wireless-AC Network Adapter - 1T1R 802.11ac WiFi Adapter | In Stock | £27.59 |
StarTech.com USB Dual-Band Wi-Fi Adapter | In Stock | £20.24 |
StarTech.com WiFi 6E USB Adapter/Dongle | In Stock | £65.15 |
