StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R
Quicklinx: 7RXVWS00 Mfr#: USB150WN1X1
Wired / Wireless: Wireless
Protocol: IEEE 802.11g, IEEE 802.11b, IEEE 802.11n
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
  • IEEE 802.11n
£12.65 ex VAT
£15.18 inc VAT
Add High Speed Wireless N Connectivity to a Desktop or Laptop Computer through USB. The USB150WN1X1 USB 802.11N Mini Wireless Network Adapter allows almost any USB-enabled desktop, laptop or netbook computer system to connect to 'n', 'g' or 'b' wireless networks. Using a 1T1R (1 Transmitter/1 Receiver) design over the 2.4GHz frequency in an extremely compact form factor, the USB adapter is capable of reaching up to 150Mbps over an 802.11n network while taking up minimal space.
Backward compatible with 802.11b/g networks (11/54Mbps), this adapter is a versatile wireless networking solution.
StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R (USB150WN1X1) - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
1.9 cm x 3.5 cm x 0.6 cm
4 g
802.11b/g/n
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
Realtek Semiconductor RTL8188CUS
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.5 - 10.14
P/N: R150WN1X1T
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
Max Range Indoors
100 m
Max Range Open Space
300 m
Full duplex mode, QoS, Ad-Hoc Mode, WPS
Aerial
Antenna
Internal
Antenna Qty
1
Processor / Memory
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA
Software Included
Drivers & Utilities
1.9 cm
3.5 cm
0.6 cm
4 g
10 - 90%
P/N: R150WN1X1T
7RXV StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R In Stock £12.65
7RXV StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter In Stock £22.54
7RXV StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - White In Stock £20.53
7RXV StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps In Stock £20.00
7RXV StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R USB WiFi Adapter - White In Stock £3.43
7RXV StarTech.com USB 2.0 300 Mbps Mini Wireless-N Network Adapter - 802.11n 2T2R WiFi Adapter In Stock £15.03
7RXV StarTech.com USB 2.0 AC600 Mini Dual Band Wireless-AC Network Adapter - 1T1R 802.11ac WiFi Adapter In Stock £27.34
7RXV StarTech.com USB Dual-Band Wi-Fi Adapter In Stock £20.05
7RXV StarTech.com WiFi 6E USB Adapter/Dongle In Stock £63.56
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
