StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0
Quicklinx: 9S40WS00 Mfr#: USB3SMDOCKHV
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black
Hurry, only 2 left in stock!
£54.99 ex VAT
£65.98 inc VAT
Create a mobile workstation using your Ultrabook or laptop USB 3.0 port via this portable USB 3.0 mini dock. The USB3SMDOCKHV USB 3.0 Laptop Mini Docking Station lets you transform your Ultrabook or laptop into a mobile workstation, by adding HDMI or VGA video output, a USB 3.0 hub port, and a Gigabit Ethernet RJ45 port, all through a single USB 3.0 host connection - a travel-friendly solution that can help you overcome the connection port limitations of modern mobile computers.
Now, you can avoid the nuisance of carrying multiple adapters. By consolidating four essential connection ports into one convenient device, the USB3SMDOCKHV delivers the perfect laptop accessory. The mini docking station features a lightweight, compact design that fits nicely into your travel bag and also features an integrated host connection cable that tucks neatly into the docking stations casing.
A versatile solution for connecting an additional display to your laptop, the mini dock offers HDMI video output with audio, or VGA video output, providing two popular interfaces for connecting a television, projector, or monitor as a second display, with support for resolutions up to 2048x1152 (QWXGA). Leveraging the high-bandwidth (5 Gbps) USB 3.0 interface to deliver flexible video output, a USB 3.0 hub port, and Gigabit Ethernet, you can quickly set up a multi-functional workstation while on the run, without sacrificing one of your laptop USB ports.
Setup is seamless and hassle-free; the mini docking station will automatically download the latest driver when connected to a Windows system with an active network connection.
  • Versatile connectivity options
    This docking station includes multiple interfaces such as HDMI and VGA, allowing users to connect various displays effortlessly.
  • Reliable compliance standards
    The device adheres to important compliance standards like FCC and RoHS, ensuring it meets safety and environmental guidelines.
  • Mac compatibility
    Tailored for Mac systems, this docking station simplifies the connection process, making it ideal for users looking to expand their workspace.
  • High-speed networking capabilities
    Equipped with Ethernet connections, this docking station supports 10Base-T, 100Base-TX, and 1000Base-T protocols for fast data transmission.
  • Suitable operating temperature range
    With a minimum operating temperature of 0°C and a maximum of 40°C, this device is built to perform well across various settings.
StarTech.com USB 3.0 to HDMI or VGA Adapter Dock - USB 3.0 Mini Docking Station w/ USB, GbE Ports - Portable Universal Laptop Travel Hub (USB3SMDOCKHV) - docking station - USB - HDMI - 1GbE
Docking station
Docking Interface
USB
Video Interfaces
HDMI
5.5 cm x 12.5 cm x 1.7 cm
100 g
Gigabit Ethernet
3-year warranty
P/N: ARMPIVOT, ARMPIVOTE, ARMPIVSTND, ARMSLIM, ARMUNONB
Docking station
5.5 cm
12.5 cm
1.7 cm
100 g
Enclosure Colour
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x display / video - output - 15 pin HD D-Sub (HD-15) , 1 x video - HDMI - 19 pin HDMI Type A
FCC, RoHS
Microsoft Windows XP (32-bit) SP3, Apple MacOS X 10.6 - 10.12, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
9S40 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
9S40 StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.54
9S40 StarTech.com DVI to VGA Cable Adapter - Black - F/M In Stock £7.33
9S40 StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
9S40 StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.74
9S40 StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio In Stock £62.58
9S40 StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video In Stock £47.08
9S40 StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £54.99
9S40 StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort In Stock £82.53
9S40 StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £7.96
9S40 StarTech.com Triple-Video Laptop Dock In Stock £89.78
9S40 StarTech.com USB-C Multiport Adapter - DVI In Stock £24.59
9S40 StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £68.98
9S40 StarTech.com USB C VGA Multiport Adapter In Stock £35.27
9S40 StarTech.com USB-C Multiport Adapter HDMI - SD Reader - 2xA 1xC - PD3.0 In Stock £59.47
9S40 StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £43.64
9S40 StarTech.com USB C Multiport Adapter 2 HDMI In Stock £63.28
9S40 StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £29.52
9S40 StarTech.com USB-C Multiport Adapter In Stock £67.04
9S40 StarTech.com USB C Multiport Adapter In Stock £81.16
9S40 StarTech.com USB-C Multiport Adapter, HDMI In Stock £31.51
9S40 StarTech.com USB-C Multiport Adapter, HDMI In Stock £27.75
9S40 StarTech.com USB-C Triple Monitor Docking Station In Stock £142.84
9S40 StarTech.com USB-C Multiport Adapter - HDMI/DP In Stock £42.02
9S40 StarTech.com USB-C Multiport Adapter - HDMI/VGA In Stock £26.89
9S40 StarTech.com USB-C Speakerphone Dock In Stock £77.32
9S40 StarTech.com USB-C Triple-Monitor Adapter In Stock £85.48
9S40 StarTech.com USB-C/USB-A Multiport Adapter In Stock £51.56
9S40 StarTech.com USB-C Triple-Monitor Adapter In Stock £85.35
Device Type: Laptop
Colour: Black
