Add HDMI and DVI-D, or HDMI and VGA dual-monitors, as well as audio and Gigabit Ethernet to your laptop through USB 3.0. The USB3SDOCKHDV Dual Video Universal USB 3.0 Laptop Docking Station with Audio and Ethernet lets you add dual HD video outputs, as well as audio and Gigabit Ethernet connections to any notebook or Ultrabook computer through a single USB 3.0 connection.
This versatile USB 3.0 docking station features three external monitor outputs (HDMI, DVI-D and VGA) that can be used in either HDMI and DVI-D, or HDMI and VGA combinations to expand or mirror your desktop. Each video output supports HD video resolutions (2048x1152 max) and HD video playback for an ideal solution to expanding your notebook's video capability.
An all-in-one mobile solution, the universal docking station combines a USB 3.0 hub (backward compatible with USB 2.0/1.1), Gigabit Ethernet RJ45 and headphone and microphone audio connectors into a single universal port replicator, perfect for enhancing laptop connectivity.
With a range of convenient connections, the dock is ideal for hoteling in shared workspaces, and for hot desks.
Display Adaptability
Offering flexible dual video combinations right out-of-the-box, this universal laptop docking station features HDMI, DVI and VGA external monitor outputs. Each video output supports HD video resolutions (2048x1152 max) and HD video playback for an ideal solution to expanding your notebook's video capability. Available display combinations: • HDMI + VGA • HDMI + DVI -
Integrated USB Hub
The built-in USB hub features three USB 3.0 ports for connecting extra peripherals such as external hard drives or a wired mouse, as if they are connected directly to your laptop. -
Direct Ethernet Connectivity
The integrated RJ45 Ethernet port supports speeds of 10/100/1000 Mbps, giving you an instant connection to a wired network. StarTech.com laptop docking stations can be used for cost savings and faster deployment with just a single cable. This USB 3.0 Docking Station is backed by a competitive 3-year warranty and free lifetime Technical Support.
- StarTech.com USB 3.0 Docking Station with HDMI and DVI/VGA - Dual Monitor - Universal Laptop Dock - Mac and Windows Compatible (USB3SDOCKHDV) - docking station - USB - VGA, HDMI - 10Mb LAN
- Product Type
- Docking station
- Docking Interface
- USB
- Video Interfaces
- VGA, HDMI
- 8.7 cm x 26.3 cm x 3.4 cm
- 289 g
- Black
- Networking
- Ethernet
- Power
- Power adapter - external AC 100/230 V
- 3-year warranty
- Designed For
- P/N: ARMBARDUO, ARMBARDUOV, ARMDUAL, ARMDUAL30, ARMDUALV, ARMSLIMDUO
- Product Type
- Docking station
- 8.7 cm
- 26.3 cm
- 3.4 cm
- 289 g
- Enclosure Colour
- Black
- Data Link Protocol
- Ethernet
- 1 x display / video - DVI-Digital (dual link) output - 24+1 pin digital DVI , 1 x audio / video - HDMI output - 19 pin HDMI Type A , 1 x network - Ethernet 1000 - RJ-45 , 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x display / video - VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio - line-out - mini-phone stereo 3.5 mm , 1 x microphone - input - mini-phone stereo 3.5 mm
- Compatible Slots
- 1 x SuperSpeed USB 3.0 - type B
- Cables Included
- 1 x SuperSpeed USB cable - external - 90 cm
- RoHS
- Power Device
- Voltage Required
- AC 100/230 V
- OS Required
- Microsoft Windows XP (32-bit) SP3, Apple MacOS X 10.6 - 10.12, Google Chrome OS 70 or later, Google Chrome OS 69, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- 0 °C
- 40 °C
- Designed For
StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio | In Stock | £56.02 |
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 | In Stock | £57.25 |
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £139.14 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £9.01 |
StarTech.com Monitor Mount - USB Passthrough | In Stock | £161.64 |
StarTech.com Dual Monitor Mount - Stackable | In Stock | £217.58 |
StarTech.com Dual Monitor Stand | In Stock | £82.12 |
StarTech.com Vertical Dual Monitor Stand | In Stock | £80.40 |
StarTech.com Vertical Dual Monitor Mount | In Stock | £72.02 |
