StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort
Quicklinx: 9X90WS00 Mfr#: USB3DOCKHDPC
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black
42 In Stock
£93.33 ex VAT
£111.99 inc VAT
Create a 4K Ultra HD or dual-monitor workstation through USB 3.0, even if your laptop doesn't natively support high-resolution output. The USB 3.0 4K Laptop Docking Station lets you create a high-resolution, 4K Ultra HD workstation in your office or at home. Now, you can discover leading-edge display technology, desktop convenience, and fast device charging by adding 4K DisplayPort, DP & HDMI dual video, USB quick-charge port, and several other vital connections to your laptop.
It's the perfect accessory for laptops and Ultrabooks, as well as your Microsoft Surface Pro 4, Surface Pro 3, Surface 3, Surface Pro 2 or Surface Book.
Deliver brilliant text and image quality, and an exciting visual experience with one of the first docking stations to support 4Kx2K (3840x2160p - 30Hz) resolution. Now, you can take advantage of the latest Ultra High Definition (UHD) displays, or prepare your workspace for the future popularity of 4K touch screens, displays, and video sources, which offer 4x as many pixels as full high-definition (1920x1080p).
Native 4K videos, applications, and graphics look crystal-clear and sharp with vivid realism, documents are crisp, and colors appear rich and more accurate. Easily add 4K capabilities to your Windows or Mac laptop, when connected to a single display via the dock DP video output and a DisplayPort-enabled 4K display. For extra display flexibility, pair the docking station with the DisplayPort to HDMI 4K Video Converter (SKU: DP2HD4KS - sold separately) to add support for a 4K HDMI-based display.
Work faster, and more efficiently! With dual monitor support (4K output not supported in dual monitor configuration), you can design an immersive, multi-display desktop proven to streamline work and save time. Be up-and-running in seconds with no headaches, simply connect DP and HDMI-enabled displays to the integrated monitor outputs and you're done.
A single USB 3.0 connection means docking your laptop (e.g. Lenovo ThinkPad, HP / Dell Ultrabook, MacBook Pro, MacBook Air) is hassle-free, too. Devices remain constantly connected, letting you overcome laptop port limitations while also eliminating the aggravation of continually reconnecting peripherals. You can even tuck the dock neatly under your laptop, to create a full-sized workstation that's organized and clutter-free. The dock is perfect for hoteling in shared workspaces, or for hot desks.
Fast-charge your tablet or smartphone, with or without a laptop connected to the dock! USB charging is fast, convenient, and easily accessible, through a side-facing, always-on USB fast-charge port that combines data throughput with support for USB Battery Charging Specification 1.2. You can create a dynamic shared workspace and get work done efficiently, while simultaneously adding charge and sync flexibility to a mobile device.
Now, you can enjoy true multitasking capability by rapid-charging your mobile device, fused with the performance and convenience of a full-sized 4K workstation. Plus, an integrated 4-port USB 3.0 hub-controller with support for UASP-enhanced performance offers faster data transfer rates, resulting in less waiting, and more productivity from your attached peripherals such as USB 3.0 external hard drives.
  • 4K Ultra HD?Resolutions
    This?4K USB docking station?supports DisplayPort plus HDMI dual video, or a single DP display at 4K Ultra HD resolutions (3840 x 2160p). Maximum Supported Resolutions*
  • Integrated USB 3.0 Hub
    The built-in USB hub features four USB 3.0 ports for connecting extra peripherals such as external hard drives or a wired mouse as if they are connected directly to your laptop.
  • USB Fast Charge
    The?USB 3.0 dock's always-on USB fast-charge port charges devices without a laptop connection and supports USB Battery Charging Specification 1.2?making it easy to charge your?tablets and other?mobile devices.
  • Direct Ethernet Connectivity
    The integrated RJ45 Ethernet port supports speeds of 10/100/1000Mbps, giving you an instant connection to a reliable wired network.
  • Easy to Use
    This?docking station with DisplayPort?and HDMI?is universally compatible, working?with Mac and Windows ?USB 3.0 equipped laptops and includes a 2ft. USB 3.0 cable for quick setup.?? StarTech.com laptop docking stations can be used for cost savings and faster deployment with just a single cable. This USB 3.0 docking station is backed by a competitive 3-year warranty and free lifetime multilingual Technical Support.
StarTech.com USB 3.0 Docking Station Dual Monitor with HDMI & 4K DisplayPort, 4x USB-A, Gigabit Ethernet, USB Type A Universal Laptop Dock with USB 3.1 Gen 1 Hub (5 Gbps) and Charging - Mac, Windows, Chrome (USB3DOCKHDPC) - docking station - USB - HDMI, DP - 1GbE
Docking station
Docking Interface
USB
Video Interfaces
HDMI, DP
7.8 cm x 22.6 cm x 3.1 cm
274 g
Gigabit Ethernet
Power adapter AC 100/230 V
3-year warranty
P/N: ARMBARDUO, ARMDUAL, ARMDUAL30, ARMSLIMDUO
Docking station
7.8 cm
22.6 cm
3.1 cm
274 g
Enclosure Colour
4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x video - HDMI - 19 pin HDMI Type A , 1 x microphone - input - mini-phone 3.5 mm 4-pole , 1 x display / video - DisplayPort - 20 pin DisplayPort
1 x SuperSpeed USB cable - external - 60.96 cm
LED indicator
FCC, RoHS
Power adapter
AC 100/230 V
Apple MacOS X 10.8 - 10.12, Google Chrome OS 55 or later, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
9X90 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.12
9X90 StarTech.com 3.5mm 3 Pin Headset Splitter In Stock £6.39
9X90 StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £21.47
9X90 StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video In Stock £85.01
9X90 StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £76.92
9X90 StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort In Stock £93.33
9X90 StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £10.55
9X90 StarTech.com Triple-Video Laptop Dock In Stock £100.82
9X90 StarTech.com 2m 6.6ft DisplayPort 1.4 Cable In Stock £14.89
9X90 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.26
9X90 StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £16.15
Device Type: Laptop
Colour: Black
