StarTech.com Universal Swivel VESA LCD Mounting Bracket for 19in Rack or Cabinet
Quicklinx: 7P1LWS00 Mfr#: RKLCDBKT
Product Type: Rack bracket, Rack bracket
£69.75 ex VAT
£83.70 inc VAT
Mount a 17-19 inch LCD panel with tilt and swivel action in a standard 19 inch rack/cabinet. The RKLCDBKT Universal Swivel VESA LCD Mounting Bracket for 19in Rack or Cabinet lets you mount almost any retail LCD or touch screen into a server rack/cabinet, with tilt and swivel motion for maximum visible range. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Hinged on one of the rail mounts, the LCD bracket can be released to swing out from the rack, as well as offering vertical tilt allowing for perfect placement of your LCD panel with minimal adjustment.
Constructed from solid cold pressed steel (SPCC), the LCD mounting bracket is designed to support 75mm and 100mm VESA mounted panels, and meets ANSI/EIA RS-310-D rack mounting standards.
A versatile option, the LCD mounting bracket also supports wall-mounted installations by reversing the bracket or attaching to a wall mounted bracket or rack.
StarTech.com Universal Swivel VESA LCD Mounting Bracket for 19in Home Server Rack or Cabinet (RKLCDBKT) mounting kit - for LCD display - black
Mounting kit
48.6 cm x 12.2 cm x 31.1 cm
Adjustable Depth
0-8.9 cm
2.7 kg
Recommended Use
LCD display
Recommended Display Size
19"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
16 kg
Material
Solid cold pressed steel
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30
48.6 cm
12.2 cm
31.1 cm
Adjustable Depth
0-8.9 cm
2.7 kg
Material
AV Furniture
Mounting kit
Recommended Use
LCD display
19"
Max Load Weight
16 kg
Adjustable depth
Limited warranty - lifetime
7P1L StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £45.05
7P1L StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £79.70
7P1L StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £48.69
7P1L StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £13.69
7P1L StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £34.96
7P1L StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel In Stock £48.81
7P1L StarTech.com 4U 19in Hinged Wall Mounting Bracket for Patch Panels In Stock £26.84
