The Universal Laptop Lock is a versatile solution compatible with Noble Wedge ; K-Slot (T-Bar), or Nano, providing flexibility and convenience. Its on-the-fly lock tip adjustment feature enables effortless compatibility with the different security slot types. The cut-resistant steel security cable measures 6.5 ft (2 m) in length and 0.17 in (4.4 mm) thick, providing reach and durability. With the 3-in-1 Laptop Lock, protect your valuable devices wherever you go.
Keyed Lock
This anti-theft laptop lock features a push-to-lock system that allows for quick-lock without a key. Unlock it without the need to remember combinations. The lock includes a set of two keys. The lock can withstand a pull force of 201 lb (91.2 kg) for K-slot, 217.8 lb (98.8 kg) for Nano, and 135 lb (61.2 kg) for Noble Wedge ; ensuring your computer or other devices remains safe from theft. Note: The pull force values mentioned may vary if the security slots do not comply with the design standards specified by their respective manufacturers. -
Widely Compatible
The versatile security lock is not limited to laptops or notebooks only. Use this lock to secure other devices such as docking stations, monitors, printers, SFF computers, projectors, oscilloscopes, or other office and lab equipment, expanding its utility. The lock is future-proof as it works with previous and newer computers from various brands, including HP, Dell, Microsoft, and more. Spacers are included to protect the device from scuffing or denting the lock slot while ensuring a better fit for your device. -
Full-Motion Lock Design
The diameter of the lock head is 0.4 in (14 mm) and features a ball joint design that allows for 360° rotation and 90° pivot of the lock head. This flexibility reduces coiling and minimizes strain on the notebook slot, enhancing durability and usability.
- StarTech.com Universal Laptop Lock 6.6ft (2m), Security Cable For Notebook Compatible With Noble Wedge®/Nano/K-Slot; Keyed Locking Cable - Anti-Theft Cut-Resistant Steel Cable (UNIVK-LAPTOP-LOCK) - security cable lock
- Product Type
- Security cable lock
- Package Content
- 2 x keys, hook-and-loop straps, 3 lock spacers
- Black, silver
- Product Material
- Plastic, steel
- 3.2 cm 1.4 cm
- Length
- 2 m
- Anti-theft protection
- 2-year warranty
- Product Type
- Product Material
- Plastic, steel
- Package Content
- 3.2 cm
- 1.4 cm
- Length
- 2 m
- Shipping Dimensions (WxDxH) / Weight
- 15 cm x 18 cm x 2 cm / 144 g
- Black, silver
Security Cable Lock
- Intended For
- Notebook
- Lock Type
- T-Bar, nano, noble wedge
- Lock Method
- Key
- Limited warranty: - 2 years
StarTech.com Universal Laptop Lock, 3-in-1 | In Stock | £27.09 |
