This universal DC power adapter has been designed as an alternative, back up or replacement power supply for StarTech.com's line of industrial USB hubs.
Compatible USB 3.0 Hubs: 10-Port Industrial USB 3.0 Hub with External Power Adapter - ESD & 350W Surge Protection (HB30A10AME); 10-Port Industrial USB 3.0 Hub with ESD & 350W Surge Protection (ST1030USBM); 7-Port Industrial USB 3.0 Hub with External Power Adapter - ESD & 350W Surge Protection (HB30A7AME); 7-Port Industrial USB 3.0 Hub with ESD & 350W Surge Protection (ST7300USBME); 4-Port Industrial USB 3.0 Hub with ESD Protection (ST4300USBMST4300USBM).
Compatible USB 2.0 Hubs: 7-Port Industrial USB 2.0 Hub ESD Protection & 350W Surge Protection (HB20A7AME); 7-Port Industrial USB 2.0 Hub with ESD & 350W Surge Protection (ST7200USBM); 4-Port Industrial USB 2.0 Hub with ESD Protection & 350W Surge Protection (HB20A4AME); 4-Port Industrial USB 2.0 Hub with ESD Protection (ST4200USBM).
The external terminal power adapter can also be used with any other devices that can support 20V power supply including a variety of StarTech.com Ethernet Switches and Serial Adapters.
- StarTech.com Universal DC Power Adapter - Industrial USB Hubs - 20V, 3.25A - power adapter
- Power adapter - external
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- Input Voltage
- AC 110-240 V
- Output Voltage
- DC 20 V
- Included Accessories
- Two conductor terminal block connector (attached), three conductor terminal block connector
- 1-year warranty
- Designed For
- P/N: HB20A4AME, HB20A7AME, HB30A10AME, HB30A7AME, ST1030USBM, ST4200USBM, ST4300USBM, ST7200USBM, ST7300USBME
- Localisation
- Input Voltage
- AC 110-240 V
- 65 Watt
- Output Voltage
- DC 20 V
- Max Electric Current
- 3.25 A
- Cables Included
- 4 x power cable - external
- UL, FCC, RoHS, PSE Mark, REACH
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 20 - 80%
- Shipping Width
- 24.2 cm
- Shipping Depth
- 16.6 cm
- Shipping Height
- 5.5 cm
- Shipping Weight
- 810 g
- Designed For
StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £58.97 |
StarTech.com Mountable Rugged Industrial 7 Port USB Hub | In Stock | £82.96 |
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £98.93 |
StarTech.com 7 Port Industrial USB 3.0 Hub | In Stock | £105.95 |
StarTech.com 10 Port Industrial USB 3.0 Hub | In Stock | £125.14 |
StarTech.com 4-Port Industrial USB 2.0 Hub | In Stock | £139.45 |
StarTech.com 7-Port Industrial USB 2.0 Hub | In Stock | £175.28 |
StarTech.com 10-Pt Industrial USB 3.0 Hub w/ Ext. Power Supply | In Stock | £157.51 |
StarTech.com DC Power Adapter - 24V/6.6A | In Stock | £62.38 |
