StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V
Quicklinx: FHJ3WS00 Mfr#: ITB20D3250
£41.80 ex VAT
£50.16 inc VAT
This universal DC power adapter has been designed as an alternative, back up or replacement power supply for StarTech.com's line of industrial USB hubs.
Compatible USB 3.0 Hubs: 10-Port Industrial USB 3.0 Hub with External Power Adapter - ESD & 350W Surge Protection (HB30A10AME); 10-Port Industrial USB 3.0 Hub with ESD & 350W Surge Protection (ST1030USBM); 7-Port Industrial USB 3.0 Hub with External Power Adapter - ESD & 350W Surge Protection (HB30A7AME); 7-Port Industrial USB 3.0 Hub with ESD & 350W Surge Protection (ST7300USBME); 4-Port Industrial USB 3.0 Hub with ESD Protection (ST4300USBMST4300USBM).
Compatible USB 2.0 Hubs: 7-Port Industrial USB 2.0 Hub ESD Protection & 350W Surge Protection (HB20A7AME); 7-Port Industrial USB 2.0 Hub with ESD & 350W Surge Protection (ST7200USBM); 4-Port Industrial USB 2.0 Hub with ESD Protection & 350W Surge Protection (HB20A4AME); 4-Port Industrial USB 2.0 Hub with ESD Protection (ST4200USBM).
The external terminal power adapter can also be used with any other devices that can support 20V power supply including a variety of StarTech.com Ethernet Switches and Serial Adapters.
StarTech.com Universal DC Power Adapter - Industrial USB Hubs - 20V, 3.25A - power adapter
Power adapter - external
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Input Voltage
AC 110-240 V
Output Voltage
DC 20 V
Two conductor terminal block connector (attached), three conductor terminal block connector
1-year warranty
P/N: HB20A4AME, HB20A7AME, HB30A10AME, HB30A7AME, ST1030USBM, ST4200USBM, ST4300USBM, ST7200USBM, ST7300USBME
Input Voltage
AC 110-240 V
65 Watt
Output Voltage
DC 20 V
Max Electric Current
3.25 A
4 x power cable - external
UL, FCC, RoHS, PSE Mark, REACH
Limited warranty - 1 year
20 - 80%
Shipping Width
24.2 cm
Shipping Depth
16.6 cm
Shipping Height
5.5 cm
Shipping Weight
810 g
FHJ3 StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £61.41
FHJ3 StarTech.com Mountable Rugged Industrial 7 Port USB Hub In Stock £85.03
FHJ3 StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £103.00
FHJ3 StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £108.59
FHJ3 StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £128.27
FHJ3 StarTech.com 4-Port Industrial USB 2.0 Hub In Stock £145.20
FHJ3 StarTech.com 7-Port Industrial USB 2.0 Hub In Stock £182.49
FHJ3 StarTech.com 7-Pt Industrial USB 3.0 Hub w/ Ext. Power Supply In Stock £121.79
FHJ3 StarTech.com 10-Pt Industrial USB 3.0 Hub w/ Ext. Power Supply In Stock £161.45
FHJ3 StarTech.com DC Power Adapter - 24V/6.6A In Stock £64.94
