Under-Desk Keyboard Tray, Clamp-on Keyboard Holder, Supports up to 12kg (26.5lb), Sliding Keyboard and Mouse Drawer with C-Clamps, Height Adjustable Keyboard Tray - Black - Ergonomic Keyboard Tray (KEYBOARD-TRAY-CLAMP1).
Height adjustable
The sliding keyboard tray clamps feature three height settings (3.9, 4.7, and 5.5 in) from the desk surface to the tray. This clamp-on keyboard tray provides a large area that supports up to 26.5 lb. -
Easy to install
Once assembled, the keyboard drawer is secured to the desk by tightening the clamps by hand. The clamps have anti-slip pads for stability and to protect the desk surface. -
Effortless use
The under-desk keyboard tray features sliding rails for easy access, The curved front edge of the tray protrudes out by 0.6 in allowing for quick location of the tray when it's retracted below the desk. The front of the keyboard and mouse tray extends up to 8.5 in from the edge of the desk. -
Comfortable
The front edge of the pull-out keyboard tray is ergonomically curved for wrist comfort. In addition, the 0.15 in lip on the back of the keyboard holder aids in preventing any equipment from falling off the edge.
- StarTech.com Under-Desk Keyboard Tray, Clamp-on Keyboard Holder, Supports up to 12kg (26.5lb), Sliding Keyboard and Mouse Drawer with C-Clamps, Height Adjustable Keyboard Tray - Black - Ergonomic Keyboard Tray (KEYBOARD-TRAY-CLAMP1) - keyboard tray
- Product Type
- Keyboard tray
- Package Content
- 5 height adjustment screws, 5 tray mounting screws, 2 L backets, 2 desk clamp, quick start guide
- Placing / Mounting
- Under-desk mountable
- Product Material
- Steel, plastic
- 31 cm x 70 cm x 3.2 cm
- Black
- 2-year warranty
- Product Type
- Keyboard tray
- Package Content
- Product Material
- Steel, plastic
- Max Load Weight
- 12 kg
- 31 cm
- 70 cm
- 3.2 cm
- Shipping Dimensions (WxDxH) / Weight
- 83 cm x 34 cm x 6.2 cm / 3.2 kg
- Black
- Anti-slip pads, ergonomic, adjustable, integrated wrist rest
- Limited warranty - 2 years ¦ Technical support - lifetime
StarTech.com Clamp-On Pegboard Organizer | In Stock | £31.32 |
