StarTech.com Under-Desk Tray
Quicklinx: H1T6WS00 Mfr#: KEYBOARD-TRAY-CLAMP1
10 In Stock
£50.32 ex VAT
£60.38 inc VAT
Under-Desk Keyboard Tray, Clamp-on Keyboard Holder, Supports up to 12kg (26.5lb), Sliding Keyboard and Mouse Drawer with C-Clamps, Height Adjustable Keyboard Tray - Black - Ergonomic Keyboard Tray (KEYBOARD-TRAY-CLAMP1).
  • Height adjustable
    The sliding keyboard tray clamps feature three height settings (3.9, 4.7, and 5.5 in) from the desk surface to the tray. This clamp-on keyboard tray provides a large area that supports up to 26.5 lb.
  • Easy to install
    Once assembled, the keyboard drawer is secured to the desk by tightening the clamps by hand. The clamps have anti-slip pads for stability and to protect the desk surface.
  • Effortless use
    The under-desk keyboard tray features sliding rails for easy access, The curved front edge of the tray protrudes out by 0.6 in allowing for quick location of the tray when it's retracted below the desk. The front of the keyboard and mouse tray extends up to 8.5 in from the edge of the desk.
  • Comfortable
    The front edge of the pull-out keyboard tray is ergonomically curved for wrist comfort. In addition, the 0.15 in lip on the back of the keyboard holder aids in preventing any equipment from falling off the edge.
StarTech.com Under-Desk Keyboard Tray, Clamp-on Keyboard Holder, Supports up to 12kg (26.5lb), Sliding Keyboard and Mouse Drawer with C-Clamps, Height Adjustable Keyboard Tray - Black - Ergonomic Keyboard Tray (KEYBOARD-TRAY-CLAMP1) - keyboard tray
Keyboard tray
Package Content
5 height adjustment screws, 5 tray mounting screws, 2 L backets, 2 desk clamp, quick start guide
Placing / Mounting
Under-desk mountable
Product Material
Steel, plastic
31 cm x 70 cm x 3.2 cm
Keyboard tray
Package Content
Placing / Mounting
Product Material
Steel, plastic
Max Load Weight
12 kg
31 cm
70 cm
3.2 cm
83 cm x 34 cm x 6.2 cm / 3.2 kg
Anti-slip pads, ergonomic, adjustable, integrated wrist rest
Limited warranty - 2 years , Technical support - lifetime
