StarTech.com Under Desk Cable Management Tray - Cord/Wire Organizer
Quicklinx: GCQHWS00 Mfr#: UDCMTRAY
£21.32 ex VAT
£25.58 inc VAT
This Cable Management Tray enables you to have a tidier desk while keeping your cables and power bars off the floor, avoiding wire tangles and trip hazards. With an area of 23.6"L x 4.5"D x 3"H (60cm x 11.4cm x 7.6cm), this cable manager offers enough room to keep all your cords in one place. It supports laptop adapters, power bars, video/printer/charge cables, and it is compatible with height adjustable standing desks.
  • Under desk cable management tray
    Organize your workstation cables with this under-desk cable tray that keeps your cords and power bars off the floor while preventing tangles & trip hazards; 23.6"L x 4.5"D x 3"H (60cm x 11.4cm x 7.6cm).
  • Strong and durable
    This durable steel cable management tray/holder has a modern and professional look with a black powder-coated finish; Heavy duty cable tray supports up to 11lb (5kg).
  • Easy installation
    Cable manager is designed for easy installation by screwing it underneath a desk surface using a screwdriver & the incl. mounting screws; Easy access to mounting holes via the pass-through holes at the bottom of the unit.
    This durable steel cable management tray/holder has a modern and professional look with a black powder-coated finish; heavy duty cable tray supports up to 11lb (5kg).
  • Easy installation
StarTech.com Under Desk Cable Management Tray, Cable Tray Organizer for Office/Standing Desk, Desk or Table Mount Cords/Wire/Power Strip Holder, Computer Cable Manager, 23-1/2"L x 4-1/2"D - Desk Cable Management (UDCMTRAY) - cable management tray
Cable management tray
Placing / Mounting
Under-desk mountable
Package Content
2 x screws
60 cm x 11.4 cm x 76 cm
1.2 kg
Product Material
Steel
RoHS
Placing / Mounting
Package Content
2 x screws
Product Material
Steel
60 cm
11.4 cm
76 cm
1.2 kg
Enclosure Colour
Mounting Kit
Included
Max load 5 kg
RoHS
Shipping Width
61.5 cm
Shipping Depth
12 cm
Shipping Height
80 cm
Shipping Weight
1.3 kg
