This Cable Management Tray enables you to have a tidier desk while keeping your cables and power bars off the floor, avoiding wire tangles and trip hazards. With an area of 23.6"L x 4.5"D x 3"H (60cm x 11.4cm x 7.6cm), this cable manager offers enough room to keep all your cords in one place. It supports laptop adapters, power bars, video/printer/charge cables, and it is compatible with height adjustable standing desks.
Under desk cable management tray
Organize your workstation cables with this under-desk cable tray that keeps your cords and power bars off the floor while preventing tangles & trip hazards; 23.6"L x 4.5"D x 3"H (60cm x 11.4cm x 7.6cm). -
Strong and durable
This durable steel cable management tray/holder has a modern and professional look with a black powder-coated finish; Heavy duty cable tray supports up to 11lb (5kg). -
Easy installation
Cable manager is designed for easy installation by screwing it underneath a desk surface using a screwdriver & the incl. mounting screws; Easy access to mounting holes via the pass-through holes at the bottom of the unit. -
Strong and durable
This durable steel cable management tray/holder has a modern and professional look with a black powder-coated finish; heavy duty cable tray supports up to 11lb (5kg). -
Easy installation
- StarTech.com Under Desk Cable Management Tray, Cable Tray Organizer for Office/Standing Desk, Desk or Table Mount Cords/Wire/Power Strip Holder, Computer Cable Manager, 23-1/2"L x 4-1/2"D - Desk Cable Management (UDCMTRAY) - cable management tray
- Product Type
- Cable management tray
- Placing / Mounting
- Under-desk mountable
- Package Content
- 2 x screws
- 60 cm x 11.4 cm x 76 cm
- 1.2 kg
- Product Material
- Steel
- Black
- RoHS
- 2-year warranty
- Product Type
- Package Content
- 2 x screws
- Product Material
- Steel
- 60 cm
- 11.4 cm
- 76 cm
- 1.2 kg
- Enclosure Colour
- Black
- Mounting Kit
- Included
- Max load 5 kg
- RoHS
- Shipping Width
- 61.5 cm
- Shipping Depth
- 12 cm
- Shipping Height
- 80 cm
- Shipping Weight
- 1.3 kg
- Limited warranty - 2 years
