Efficient organization
The under-desk cable management tray from StarTech.com offers a neat solution for keeping cables and wires organized and out of sight. Its adjustable length and clamp mount design ensure a perfect fit for any desk setup, making it an essential accessory for maintaining a clutter-free workspace. -
Durable construction
Crafted with high-quality steel and finished with a powder coat, this cable management tray is designed to withstand the weight of up to 5 kg. The construction ensures long-lasting durability and reliability, keeping your cables securely managed and protected. -
Easy installation
This model comes complete with everything needed for installation, including 2 desk clamps, a 3 mm hex key, and 8 M5x6mm screws. The clamp-on installation allows for quick and easy setup without the need for drilling, making it suitable for both home and office environments.
- StarTech.com Under Desk Cable Management Tray, Clamp-on Installation - cable management tray
- Product Type
- Cable management tray
- Placing / Mounting
- Under-desk mountable
- Package Content
- 3 mm hex key, inner cable tray, outer cable tray, 2 x desk clamps, 8 x M5x6mm screw
- White
- Product Material
- Steel
- 10.5 cm 20.7 cm
- Length
- 120 cm
- 2.3 kg
- Adjustable length, clamp mount
- 2-year warranty
- Product Type
- Product Material
- Steel
- Package Content
- 10.5 cm
- 20.7 cm
- Length
- 120 cm
- 2.3 kg
- White
- Finish
- Powder coat
- Weight Limit
- 5 kg
- Limited warranty: - 2 years
- 10 °C
- 30 °C
StarTech.com 6ft DisplayPort 1.4 8K 60Hz | In Stock | £14.98 |
StarTech.com Clamp-On Pegboard Organizer | In Stock | £31.32 |
