StarTech.com Under Desk Cable Management - White
Quicklinx: HVM7WS00 Mfr#: CALW-DESK-CABLE-TRAY
£33.08 ex VAT
£39.69 inc VAT
  • Efficient organization
    The under-desk cable management tray from StarTech.com offers a neat solution for keeping cables and wires organized and out of sight. Its adjustable length and clamp mount design ensure a perfect fit for any desk setup, making it an essential accessory for maintaining a clutter-free workspace.
  • Durable construction
    Crafted with high-quality steel and finished with a powder coat, this cable management tray is designed to withstand the weight of up to 5 kg. The construction ensures long-lasting durability and reliability, keeping your cables securely managed and protected.
  • Easy installation
    This model comes complete with everything needed for installation, including 2 desk clamps, a 3 mm hex key, and 8 M5x6mm screws. The clamp-on installation allows for quick and easy setup without the need for drilling, making it suitable for both home and office environments.
StarTech.com Under Desk Cable Management Tray, Clamp-on Installation - cable management tray
Cable management tray
Placing / Mounting
Under-desk mountable
Package Content
3 mm hex key, inner cable tray, outer cable tray, 2 x desk clamps, 8 x M5x6mm screw
White
Product Material
Steel
10.5 cm 20.7 cm
Length
120 cm
2.3 kg
Adjustable length, clamp mount
Placing / Mounting
Product Material
Steel
Package Content
10.5 cm
20.7 cm
Length
120 cm
2.3 kg
White
Finish
Powder coat
Weight Limit
5 kg
Limited warranty: - 2 years
10 °C
30 °C
HVM7 StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £14.98
HVM7 StarTech.com Clamp-On Pegboard Organizer In Stock £31.32
