Efficient organization
The under-desk cable management tray from StarTech.com offers a neat solution for organizing and concealing cables under your desk, reducing clutter and maintaining a tidy workspace. -
Easy installation
Featuring clamp-on installation, this cable management tray can be easily attached to the edge of your desk, providing a secure and stable setup without the need for drilling or permanent modifications. -
Durable design
Constructed from steel with a black powder-coated finish, the cable management tray is made for durability and long-lasting use, supporting a weight limit of up to 5 kg. -
Adjustable configuration
With adjustable length and the inclusion of desk clamps, a hex key, and screws, the cable management tray offers flexibility to fit various desk sizes and cable volumes, ensuring a custom fit for your specific needs.
- StarTech.com Under Desk Cable Management Tray, Clamp-on Installation - cable management tray
- Product Type
- Cable management tray
- Placing / Mounting
- Under-desk mountable
- Package Content
- 3 mm hex key, inner cable tray, outer cable tray, 2 x desk clamps, 8 x M5x6mm screw
- Black
- Product Material
- Steel
- 10.5 cm 20.7 cm
- Length
- 80 cm
- 2.3 kg
- Adjustable length, clamp mount
- 2-year warranty
- Product Type
- Product Material
- Steel
- Package Content
- 10.5 cm
- 20.7 cm
- Length
- 80 cm
- 2.3 kg
- Black
- Finish
- Black powder-coated
- Weight Limit
- 5 kg
- Limited warranty: - 2 years
- 10 °C
- 30 °C
StarTech.com 6ft DisplayPort 1.4 8K 60Hz | In Stock | £14.98 |
