StarTech.com Under Desk Cable Management - Black
Quicklinx: HVM6WS00 Mfr#: CALB-DESK-CABLE-TRAY
40 In Stock
£30.92 ex VAT
£37.10 inc VAT
  • Efficient organization
    The under-desk cable management tray from StarTech.com offers a neat solution for organizing and concealing cables under your desk, reducing clutter and maintaining a tidy workspace.
  • Easy installation
    Featuring clamp-on installation, this cable management tray can be easily attached to the edge of your desk, providing a secure and stable setup without the need for drilling or permanent modifications.
  • Durable design
    Constructed from steel with a black powder-coated finish, the cable management tray is made for durability and long-lasting use, supporting a weight limit of up to 5 kg.
  • Adjustable configuration
    With adjustable length and the inclusion of desk clamps, a hex key, and screws, the cable management tray offers flexibility to fit various desk sizes and cable volumes, ensuring a custom fit for your specific needs.
StarTech.com Under Desk Cable Management Tray, Clamp-on Installation - cable management tray
Cable management tray
Placing / Mounting
Under-desk mountable
Package Content
3 mm hex key, inner cable tray, outer cable tray, 2 x desk clamps, 8 x M5x6mm screw
Product Material
Steel
10.5 cm 20.7 cm
Length
80 cm
2.3 kg
Adjustable length, clamp mount
Placing / Mounting
Product Material
Steel
Package Content
10.5 cm
20.7 cm
Length
80 cm
2.3 kg
Finish
Black powder-coated
Weight Limit
5 kg
Limited warranty: - 2 years
10 °C
30 °C
HVM6 StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £14.98
HVM6 StarTech.com Clamp-On Pegboard Organizer In Stock £31.32
