StarTech.com Ultra-Slim TV Wall Mount
Quicklinx: JG68WS00 Mfr#: 65SAP2-TV-WALL-MOUNT
£240.28 ex VAT
£288.33 inc VAT
Mount a TV to a wall using this space-saving, low-profile mount with premium finish
Create a TV mounting solution with this articulating wall mount that supports up to 65-inch televisions and 99lb (45kg). Use in conference rooms, customer-facing applications, and collaborative spaces where durability, precision, and presentation matter.
Ultra-slim Articulating Television Mount
Mount sits just 1.5in (4cm) from the wall for a sleek, unobtrusive look and extends to a maximum of 23.6in (60cm) when needed. For perfect screen positioning, you can tilt (+2°/-12°); swivel (+/-60°); and rotate (+/-2°) the display. The dual articulating arms and wider wall plate (16in North America spacing) provide smooth motion and stability during adjustments.
Versatile Mounting with a Premium Finish
This VESA-compatible wall mount supports patterns up to 600x400mm and includes hardware, spacers, and a wall template for clean installation. It secures to wood studs, brick, or concrete surfaces, offering flexibility across environments. Integrated cable channels keep wires organized, while the silver steel and aluminum frame with decorative covers creates a refined, professional look from any angle.
