StarTech.com UK Computer Power Cable, 18AWG
Quicklinx: GVKSWS00 Mfr#: BS13U-1M-POWER-LEAD
Length: 1m
22 In Stock
£5.90 ex VAT
£7.08 inc VAT
3ft (1m) UK Computer Power Cable, BS 1363 to C13 Power Cord, 18AWG, 10A 250V, Black Replacement AC Power Cord, Monitor Power Cable, BS 1363 to IEC 60320 C13 Kettle Lead - PC Power Supply Cable (BS13U-1M-POWER-LEAD).
  • Reliable connectivity
    Equipped with a power BS 1363 plug and power IEC 60320 C13 connector, this cable ensures a stable connection for your electronic devices.
  • Durable construction
    The cable features a PVC jacket that provides protection against wear and tear, maintaining its performance over time.
  • User-friendly design
    Flexible design and strain relief feature allow for easy maneuverability and reduce stress on the cable during use.
  • Meets safety standards
    This power cable complies with essential safety standards including VDE, RoHS, and WEEE, ensuring its safe usage in various environments.
  • Suitable for high voltage
    With a rated voltage of AC 250 V and a rated current of 10 A, this cable is suitable for powering a variety of high voltage devices.
StarTech.com 3ft (1m) UK Computer Power Cable, BS 1363 to C13 Power Cord, 18AWG, 10A 250V, Black Replacement AC Power Cord, Monitor Power Cable, BS 1363 to IEC 60320 C13 Kettle Lead - PC Power Supply Cable (BS13U-1M-POWER-LEAD) - power cable - BS 1363 to power IEC 60320 C13 - 1 m
Power cable
Molded, flexible, strain relief
Length
1 m
United Kingdom
Connector
Power BS 1363 - plug
Connector (Second End)
Power IEC 60320 C13
Rated Voltage
AC 250 V
Rated Current
10 A
Power cable
Jacket Material
PVC
American Wire Gauge (AWG)
18
Rated Voltage
AC 250 V
Rated Current
10 A
Length
1 m
Outside Diameter
6.8 mm
United Kingdom
Connector
Power IEC 60320 C13
VDE, RoHS, WEEE, VW-1
Shipping Width
14 cm
Shipping Depth
31 cm
Shipping Height
5.5 cm
Shipping Weight
164 g
Length: 1m
