StarTech.com U.3 to PCIe Adapter Card
Quicklinx: HDGDWS00 Mfr#: PEX4SFF8639U3
Type: USB adapter
Compatibility: PC
Interface: [N/A]
12 In Stock
£32.58 ex VAT
£39.09 inc VAT
Add a 2.5 inch U.3 NVMe SSD into a PCIe 4.0 x4/x8/x16 slot in a desktop or server using the included screws, enabling ultra-fast data access.
  • Add U.3 Capabilities to a Desktop or Server
    Install an SFF-TA-1001 SSD into a desktop or server using an available PCI Express 4.0 slot. The pre-installed full-profile bracket and included drive mounting screws enable the connection of a U.3 NVMe drive to a PCIe slot, avoiding the need for a drive backplane or additional cables. This adapter is not compatible with U.2 drives.
  • Universal Compatibility
    The Adapter Card is backward compatible with motherboards that feature x4, x8, and/or x16 PCIe 3.0 slots. The U.3 Adapter requires no additional drivers or software and works with all workstation and server operating systems, such as Windows, Windows Server, and Linux.
  • Optimal Airflow and Reliable Performance
    The vented full-profile bracket and a large cutout in the PCB allow for better airflow and heat dissipation, which helps maintain optimal and reliable performance while avoiding thermal throttling.
StarTech.com U.3 to PCIe Adapter Card, PCIe 4.0 x4 Adapter For 2.5" U.3 NVMe SSDs, SFF-TA-1001 PCI Express Add-in Card for Desktops/Servers, TAA Compliant - OS Independent (PEX4SFF8639U3) - interface adapter - U.3 NVMe - PCIe 4.0 x4 - TAA Compliant
Interface adapter - plug-in card
Bus Type
PCIe 4.0 x4
Red
Hard Drive Form Factor Compatibility
2.5"
U.3 NVMe
Supported Devices
Solid state drive
Max Storage Devices Qty
1
Product Material
UL94-V0
TAA Compliant
1.5 cm x 15.4 cm x 9 cm
62 g
2.5"
Hard Drive Maximum Height
15 mm
Host Bus
PCIe 4.0 x4
Product Material
UL94-V0
Red
Storage Controller
U.3 NVMe
Supported Devices
Solid state drive
1
1 x U.3 NVMe - U.3 (SFF-TA-1001)
1 x PCIe 3.0 , 1 x U.3 NVMe
Full-profile bracket, 4 x screws
LED indicator
Mounting Kit
Included
MTBF
21,693,912 hours
RoHS, WEEE
Environmental Standards
TAA Compliant
1.5 cm
15.4 cm
9 cm
62 g
Shipping Width
21.5 cm
Shipping Depth
15.5 cm
Shipping Height
3 cm
Shipping Weight
130 g
60 °C
20 - 80%
Type: USB adapter
Compatibility: PC
Interface: [N/A]
