StarTech.com TV Wall Mount - Tilting
Quicklinx: F2GGWS00 Mfr#: FPWTLTB1
Type: Bracket
27 In Stock
£59.20 ex VAT
£71.04 inc VAT
Save space and create an impressive display by wall-mounting a large TV in a boardroom or customer-facing area. This tilting flat-screen TV wall mount securely supports a TV up to 100"and features an attractive low-profile design.
Mount your large flat-screen TV in a location that's convenient for visitors, clients and employees. Create an engaging display to keep guests informed or entertained, ideal in lobbies, lecture halls, restaurants, health care centers and other meeting spaces.
The television wall mount supports most 60" to 100" (812.8 to 1778 mm) LED or LCD flat panel TVs weighing up to 165 lb. (75 kg). It also supports curved TVs, with a compatible VESA mount up to 900x600.
Find the ideal viewing angle. The tilting TV wall mount lets you tilt your display up (maximum 5 degrees) or down (maximum 10 degrees) with ease.
Save space with this slim TV wall mount. With its low-profile design, your TV sits just 3.3" (85 mm) from the wall.
The heavy-duty TV mounting bracket securely supports your large flat-screen TV and is easy to install. The spring locks allow quick attachment and release. The open architecture provides ventilation and easy access to wires.
  • Create an Engaging Display for Digital Signage
    Mount your large flat-screen TV in a location that's convenient for visitors, clients and employees. Create an engaging display to keep guests informed or entertained, ideal in lobbies, lecture halls, restaurants, health care centers and other meeting spaces. The television wall mount supports most 60" to 100" (812.8 to 1778 mm) LED or LCD flat panel TVs weighing up to 165 lb. (75 kg). It also supports curved TVs, with a compatible VESA mount up to 900x600.
  • Tilting Design for Optimal Viewing
    Find the ideal viewing angle. The tilting TV wall mount lets you tilt your display up (maximum5 degrees) or down (maximum 10 degrees) with ease.
StarTech.com TV Wall Mount supports 60-100 inch VESA Displays (165lb/75kg), Heavy Duty Tilting Universal TV Wall Mount, Adjustable Mounting Bracket for Large Flat Screens, Low Profile - Slim TV Wall Mount (FPWTLTB1) bracket - for TV - black
Bracket - wall-mountable
62.5 cm x 95.4 cm x 8.5 cm
Tilt
-10° to 5°
Adjustments
Tilt
3.5 kg
Recommended Use
TV
Recommended Display Size
60"-100"
VESA Mounting Interface
200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 600 x 400 mm, 300 x 200 mm, 600 x 600 mm, 800 x 600 mm, 900 x 600 mm, 300 x 300 mm
Max Load Weight
75 kg
Material
Plastic, steel
Package Content
4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 8 x spacers (small), 6 x concrete anchors, 4 x M8x50 screws, 4 x rectangular washers, 2 x vertical brackets, 8 x spacers (large), level, 6 x washers, 2 x tilt-adjustment knobs, 6 x wall screws
62.5 cm
95.4 cm
8.5 cm
3.5 kg
Material
Plastic, steel
Package Content
AV Furniture
Bracket
Recommended Use
TV
Placing / Mounting
Wall-mountable
60"-100"
Tilt
-10° to 5°
Adjustments
Tilt
Max Load Weight
75 kg
Dimensions & Weight Details
3.7 kg
F2GG StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.85
F2GG StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £78.22
Type: Bracket
