StarTech.com TV/Monitor Arm - Wallmount
Quicklinx: CFR4WS00 Mfr#: ARMPIVWALL
Accessory Type: Mount
£82.22 ex VAT
£98.66 inc VAT
Wall mount a monitor to save space, and adjust your viewing angle with one-touch height adjustment. Free up valuable desk or table space by wall-mounting your flat-panel display (TV or computer monitor). This full-motion monitor arm supports monitors and TVs up to 30" and provides effortless height and viewing angle adjustments. You can tilt, swivel, and rotate your screen, making it easy to find the perfect viewing position.
This sturdy mounting arm helps you save space on your desk or table surface, by letting you securely wall-mount a computer monitor or flat-screen TV, up to 30" in size. It’s ideal for many different office applications, such as healthcare or financial settings, where you may want to share your display with patients, clients, or other visitors. The wall-mountable monitor arm also works well in office settings or workspaces that back against a wall.
You can also tuck your monitor in closely to the wall, to save more space while you’re not working on your computer.
The monitor arm features a gas-spring cylinder, which makes it easy to raise or lower your display. You can also adjust the tension according to the weight of your monitor, so you can re-position the monitor height at any time, with one touch. Easy one-touch height adjustment makes the monitor arm ideal for shared workspaces with multiple alternating users, such as hotel meeting rooms or office boardrooms.
The full-motion articulating arm makes it easy to find the right viewing angle. Just tilt or swivel your monitor to share your display, while collaborating with others. The articulating arm also supports a full 360-degree rotation, so it’s easy to switch from landscape to portrait orientation, and back again.
The single-monitor arm makes wall-mounting your VESA compatible monitor fast and easy. It requires minimal assembly and features a built-in level, which helps you to position the arm assembly perfectly upright when mounting it to the wall. The mount also makes it easy to attach or remove your monitor with ease, and features built-in cable management to help keep your cables neat and tidy.
  • Versatile design
    The adjustable arm accommodates a variety of monitor sizes from 12 to 34 inches, making it suitable for different setups.
  • Extensive motion adjustments
    With a tilt of -65° to 90°, a 180° pan, and 360° rotation, users can easily adjust their monitors to achieve the optimal viewing angle.
  • Sturdy construction
    Made from a combination of aluminum and steel, this mount provides reliable support for your monitor.
  • Clean installation
    Integrated cable management helps prevent clutter by securely organizing and concealing wires, enhancing workspace aesthetics.
  • Complete mounting kit
    The package includes all necessary components such as washers, spacers, anchors, and screws for seamless mounting.
StarTech.com Wall Mount Monitor Arm - Full Motion Articulating - Adjustable - Supports Monitors 12” to 34” - VESA Monitor Wall Mount - Black (ARMPIVWALL) mounting kit - adjustable arm - for flat panel - black
Mounting kit (adjustable arm) - wall-mountable
Mounting Components
Wall plate, 2 washers, 4 spacers, cover, 2 anchors
11.5 cm x 62 cm x 10.8 cm
Tilt
-65° to 90°
Pan
180°
Rotation
360°
Adjustments
2 kg
Recommended Use
Flat panel
Recommended Display Size
12"-30"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
9 kg
Material
Aluminium, steel
Package Content
M5 allen key, 4 x M4x12 screws, 4 x M4x25 screws, M6 screw, 2 x 6.3x65mm screws, zip tie
P/N: ACCSMNT
11.5 cm
62 cm
10.8 cm
2 kg
Material
Aluminium, steel
Package Content
AV Furniture
Mounting kit
Mounting Components
Design
Adjustable arm
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
Cable Management
12"-30"
Tilt
-65° to 90°
Pan
180°
Rotation
360°
Adjustments
Max Load Weight
9 kg
P/N: ACCSMNT
CFR4 StarTech.com Thin Client Mount - VESA In Stock £22.48
CFR4 StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £50.12
CFR4 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.71
CFR4 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
CFR4 StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.34
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: CFR4 051349
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £11.53
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Stock Status: Used Stock
