Wall mount a monitor to save space, and adjust your viewing angle with one-touch height adjustment. Free up valuable desk or table space by wall-mounting your flat-panel display (TV or computer monitor). This full-motion monitor arm supports monitors and TVs up to 30" and provides effortless height and viewing angle adjustments. You can tilt, swivel, and rotate your screen, making it easy to find the perfect viewing position.
This sturdy mounting arm helps you save space on your desk or table surface, by letting you securely wall-mount a computer monitor or flat-screen TV, up to 30" in size. It’s ideal for many different office applications, such as healthcare or financial settings, where you may want to share your display with patients, clients, or other visitors. The wall-mountable monitor arm also works well in office settings or workspaces that back against a wall.
You can also tuck your monitor in closely to the wall, to save more space while you’re not working on your computer.
The monitor arm features a gas-spring cylinder, which makes it easy to raise or lower your display. You can also adjust the tension according to the weight of your monitor, so you can re-position the monitor height at any time, with one touch. Easy one-touch height adjustment makes the monitor arm ideal for shared workspaces with multiple alternating users, such as hotel meeting rooms or office boardrooms.
The full-motion articulating arm makes it easy to find the right viewing angle. Just tilt or swivel your monitor to share your display, while collaborating with others. The articulating arm also supports a full 360-degree rotation, so it’s easy to switch from landscape to portrait orientation, and back again.
The single-monitor arm makes wall-mounting your VESA compatible monitor fast and easy. It requires minimal assembly and features a built-in level, which helps you to position the arm assembly perfectly upright when mounting it to the wall. The mount also makes it easy to attach or remove your monitor with ease, and features built-in cable management to help keep your cables neat and tidy.
- StarTech.com Wall Mount Monitor Arm - Full Motion Articulating - Adjustable - Supports Monitors 12” to 34” - VESA Monitor Wall Mount - Black (ARMPIVWALL) mounting kit - adjustable arm - for flat panel - black
- Product Type
- Mounting kit (adjustable arm) - wall-mountable
- Mounting Components
- Wall plate, 2 washers, 4 spacers, cover, 2 anchors
- 11.5 cm x 62 cm x 10.8 cm
- Tilt
- -65° to 90°
- Pan
- 180°
- Rotation
- 360°
- Adjustments
- 2 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 12"-30"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 9 kg
- Material
- Aluminium, steel
- Black
- Package Content
- M5 allen key, 4 x M4x12 screws, 4 x M4x25 screws, M6 screw, 2 x 6.3x65mm screws, zip tie
- 2-year warranty
- Designed For
- P/N: ACCSMNT
- 11.5 cm
- 62 cm
- 10.8 cm
- 2 kg
- Material
- Aluminium, steel
- Black
- Package Content
AV Furniture
- Mounting kit
- Design
- Adjustable arm
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- Cable Management
- Integrated cable management
- 12"-30"
- Tilt
- -65° to 90°
- Pan
- 180°
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 9 kg
- Limited warranty - 2 years
- Designed For
- P/N: ACCSMNT
StarTech.com Thin Client Mount - VESA | In Stock | £23.19 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £51.28 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £58.71 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £75.65 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £8.54 |
