StarTech.com TV Cart for 32"-70" Displays
Quicklinx: CZYZWS00 Mfr#: STNDMTV70
12 In Stock
£350.65 ex VAT
£420.78 inc VAT
Create a mobile media center with this TV cart, supporting a 32" to 70" flat-screen TV. This portable TV cart makes it easy to create a mobile media center, providing a convenient and cost-effective way to share A/V equipment between rooms. Engineered with a sleek and sturdy design, the TV cart provides a secure mount for a 32" to 70" TV (with maximum weight of 66 lb./30 kg) and a removable multi-media shelf for placing your computer, media player or keyboard. It also includes a camera shelf for web-conferencing.
The mobile TV cart saves you the cost of buying multiple flat-panel TVs. Simply roll the TV cart between boardrooms, classrooms and meeting rooms, to share your media equipment. The cart features a small footprint that enables you to stand close to the display, while delivering a presentation. You can also set up a display in your lobby during special events or set up a permanent display in areas where you can't wall mount. The wheels are lockable for stationary use.
With the TV cart's spring-assisted height adjustment, you can raise or lower the display mount with one smooth motion, from a minimum height of 3.6 ft. (1110 mm) to a maximum height of 4.9 ft. (1510 mm) - a lift of up to 15.7 in. (40 cm). The TV mount rotates up to 90°, so you can change the position of your display from landscape to portrait. You can also tilt your TV +5° to -12°, to find the optimal viewing angle.
The TV cart's durable construction makes it ideal for commercial use, in environments with multiple users and frequent movement between meeting areas. Built-in cable management keeps your cables organized and hidden from view.
  • Move Your Media Center from Room to Room
  • Adjust Your Display with Ease
    With the TV cart's spring-assisted height adjustment, you can raise or lower the display mount with one smooth motion, from a minimum height of 3.6 ft. (1110 mm) to a maximum height of 4.9 ft. (1510 mm) - a lift of up to 15.7 in. (40 cm). The TV mount rotates up to 90 degrees, so you can change the position of your display from landscape to portrait. You can also tilt your TV +5 to -12 degrees, to find the optimal viewing angle.
StarTech.com Heavy Duty Rolling Portable TV Cart Stand with Wheels - 32 to 75 inch - Adjustable Rotating Mobile Flat Panel Screen Mount (STNDMTV70) cart - for flat panel - black, silver
Cart
82.8 cm x 70 cm x 214 cm
Tilt
-12° to 5°
Lift
40 cm
Rotation
-90° to 90°
Adjustments
25.1 kg
Recommended Use
Flat panel
Recommended Display Size
32"-70"
VESA Mounting Interface
200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Load Weight
30 kg
Material
Plastic, aluminium, steel
Black, silver
Wheels Qty
4
Package Content
4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 4 x washers, 8 x spacers (small), hex key, 4 x end caps, 4 x M8x50 screws, 6 x M6x8 screws, 4 x M8x25 screws, wrench, left leg, right leg, left cover, right cover, support plate, column, connecting plate, camera shelf, plastic cover, left/right support brackets, column cover, multimedia shelf, 3 x cable clips, 2 x crossbars, 2 x hook and loop ties, 4 x M6x16 screws, 2 x M6x25 screws, 2 x support plate nuts, 3 x countersunk screws, 2 x M4x6 screws, 10 x M6x14 screws, caster wrench, 4 x shelf spacers, 4 x TV washers, 8 x spacers (large)
5-year warranty
P/N: HDMIPLATE
82.8 cm
70 cm
214 cm
25.1 kg
Material
Black, silver
Package Content
AV Furniture
Cart
Recommended Use
Flat panel
Cable Management
Integrated cable management
32"-70"
Tilt
-12° to 5°
Lift
40 cm
Rotation
-90° to 90°
Adjustments
Max Load Weight
30 kg
Wheels Qty
4
Assembly Required
Limited warranty - 5 years
P/N: HDMIPLATE
CZYZ StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter In Stock £36.95
CZYZ StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable In Stock £5.32
CZYZ StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.83
CZYZ StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £78.22
CZYZ StarTech.com Mobile TV Cart, Portable/Rolling TV Stand 37-70" In Stock £299.18
CZYZ StarTech.com Mobile TV Stand - Heavy Duty TV Cart for 60-100" TVs In Stock £392.12
CZYZ StarTech.com Rolling TV Cart/Portable Mount In Stock £445.42
