Universal Media Player Mount Adjustable Cradle Devices Up to 11 lb. (5 kg). Mount your devices like media players, video extenders or cable boxes to the wall or the back of your TV with this StarTech.com tv accessory mount.
Flexible Mounting Options
This TV mount bracket offers a variety of mounting options; with a 13.4"x8.8" grid of mounting holes, the bracket can be mounted to a wall or to the back of your TV using VESA screw holes or to a VESA bracket.
Store a Variety of Products
The media device mount is ideal for devices like media players, Apple TV, video extenders, modems, and cable boxes that can be attached directly to the mounting grid with the included reusable cable ties. For heavier devices (up to 11 lb. / 5 kg) an optional cradle (adjustable depth from 1.8" to 3") is included.
The mount also comes with reusable cable ties and an elastic band to help keep your devices secure; and a foam strip to protect your devices from scratches.
Hassle-Free Access
The open frame design of the mount allows for unrestricted access to your media devices.
MDBOXMNT is backed by a StarTech.com 5-year warranty and free lifetime technical support.
Flexible mounting options
This TV mount bracket offers a variety of mounting options; with a 13.4" x 8.8" grid of mounting holes, the bracket can be mounted to a wall or to the back of your TV using VESA screw holes or to a VESA bracket. -
Store a variety of products
The media device mount is ideal for devices like media players, Apple TV, video extenders, modems, and cable boxes that can be attached directly to the mounting grid with the included reusable cable ties. -
Hassle-free access
- StarTech.com Universal TV Accessory Mount, Adjustable TV & Wall Mount Bracket, Media Players/Router/Modem/AV Switches & Extenders/Apple TV, Hidden Cable Box Mount Behind TV, 11lb (5kg) - Adjustable Cradle (MDBOXMNT) - mounting kit - for media player - black
- Product Type
- Mounting kit - wall-mountable, TV mount
- 22.4 cm x 34.2 cm x 8.6 cm
- Recommended Use
- Media player
- Max Load Weight
- 5 kg
- Material
- Powder-coated steel
- Black
- Package Content
- Mounting hardware, 2 x M6x14 screws, 2 x wall screws, 2 x nuts, 3 x zip ties, elastic band, 2 x 20 mm washers, 2 x M5x10 screws, 2 x M4x14 screws, 2 x M8x15 screws, 2 x 12 mm washers, 2 x wall anchors, EVA foam strips
- 5-year warranty
- Designed For
- P/N: FPWHANGER, FPWTLTPORT, MBLTVSTNDEC
- 22.4 cm
- 34.2 cm
- 8.6 cm
- Material
- Black
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- Media player
- Placing / Mounting
- Wall-mountable, TV mount
- Max Load Weight
- 5 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 35.5 cm x 22.8 cm x 5.8 cm / 1.1 kg
- Limited warranty - 5 years
- Designed For
