StarTech.com Tripod Floor Stand for Tablets
Quicklinx: C9WWWS00 Mfr#: STNDTBLT1A5T
Device Type: Tablet
Type: Tablet Stand
Device Screen Size: 6.5 - 7.8
Colour: Black
12 In Stock
£50.66 ex VAT
£60.79 inc VAT
Standard delivery Delivered within 3-5 working days
Use your tablet hands-free with this portable and adjustable tripod. Deliver your presentations, using your tablet as a visual aid, without the disruption or distraction of having to hold your tablet. This tablet-mount tripod stand is perfect for presenting in front of a group, on stage or as part of a product display. Simply put your Apple iPad, Samsung Galaxy, Microsoft Surface Pro 3 or 4, or other tablet into the tablet mount, adjust the height and viewing angle, and you're ready for show time.
This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
For your presentations to have maximum impact, you need to eliminate distractions so that you can focus on your audience and the content you're delivering. This convenient tripod holds your tablet in place at a comfortable height, so you don't have to. You can use your tablet as a visual cue, without having to hold it or repeatedly look down at it while you're speaking to an audience.
The tablet-mount tripod stand is perfect for the boardroom, portable displays, sales training, music studios, concerts, classrooms and many other applications, with no need for a podium. Since the height of the stand is easy to adjust - from 74.5 cm (29.3 in.) to 157.5 cm (62 in.) - you can use it while you're sitting or standing, depending on what's comfortable for you. You can even use it to shoot video or photos with a steady hand.
With the tripod floor stand, you can also use your tablet to deliver powerful presentations to larger audiences. By connecting your tablet to a mirroring device, you can wirelessly present from your tablet, mirroring your tablet to the room's projector or large display. With the tablet securely in place on the tripod stand, your hands are free to navigate through your presentation or point to the big screen.
You can rotate the tablet mount 360 degrees. Change your tablet to a landscape or portrait position, without moving it from the mount. You can also tilt the screen to your preferred viewing angle, and change it easily with one touch.
The universal tablet mount fits tablets ranging in size from 7 in. to 11 in. (with a maximum tablet thickness of 11.5 mm). The tablet mount is also detachable, with quick-swap attachments that let you remove the tablet from the stand and place it back in at any time.
The tablet tripod folds up easily and comes in a handy carrying bag for portability.
Setup is easy with virtually no assembly required - just extend the collapsible tripod stand to the height you need, lock it in place, and mount your iPad or other tablet.
  • Robust construction
    The steel material used in the Adjustable Tablet Tripod Stand ensures durability and stability, providing a reliable mounting solution for your tablet.
  • Versatile adjustments
    With features such as height, pan, and tilt adjustments, users can easily modify the stand to achieve their desired viewing angle and height.
  • 360° rotation capability
    This feature allows users to rotate the tablet to any angle, making it ideal for different applications, from presentations to video streaming.
  • Lightweight and portable
    The included carrying bag enhances portability, allowing users to take the tripod stand anywhere, whether for professional use or personal enjoyment.
  • Maximum load capacity
    The stand supports a maximum weight of 1 kg, ensuring that it can securely hold various tablets without any risk of tipping over.
Startech Adjustable Tablet Tripod Stand - Portable Tablet Mount - 6.5 to 7.8" W. Tablets - Carrying Bag Included - Tablet Tripod Mount (STNDTBLT1A5T) mounting kit - for tablet
Mounting kit - desktop
Mounting Components
Holder, floor stand
61 cm x 61 cm x 74.5 cm
Rotation
360°
Adjustments
Height, pan, tilt
2 kg
Recommended Use
Tablet
Recommended Display Size
6.5"-7.8"
Max Load Weight
1 kg
Material
Steel
P/N: ARMTBLTUGN
61 cm
61 cm
74.5 cm
2 kg
Material
Steel
AV Furniture
Mounting kit
Mounting Components
Holder, floor stand
Recommended Use
Tablet
Placing / Mounting
Desktop
6.5"-7.8"
Rotation
360°
Adjustments
Height, pan, tilt
Max Load Weight
1 kg
P/N: ARMTBLTUGN
C9WW StarTech.com 11 Piece PC Computer Tool Kit with Carrying Case In Stock £14.09
C9WW StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
C9WW StarTech.com Tripod Floor Stand for Tablets In Stock £50.66
C9WW StarTech.com Lockable Floor Stand for iPad In Stock £137.81
C9WW StarTech.com Tablet Stand - Desk/Wall Mount In Stock £27.26
C9WW StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black In Stock £8.64
C9WW StarTech.com 2 m / 6.6 ft USB 2.0 to USB C Cable – Black In Stock £10.10
C9WW StarTech.com 1 m / 3.3 ft USB C Cable – Black In Stock £8.89
C9WW StarTech.com VESA Mount Adapter for Tablets In Stock £22.48
C9WW StarTech.com Adjustable Tablet Stand In Stock £28.89
Device Type: Tablet
Type: Tablet Stand
Colour: Black
