StarTech.com Triple-Video Laptop Dock
Quicklinx: BM03WS00 Mfr#: USB3DOCKH2DP
More than 50 in stock
£149.59 ex VAT
£179.50 inc VAT
Create an Ultra HD workstation with four displays, by adding three external monitors to your laptop. This triple-video docking station for laptops merges cutting-edge technology and high-quality hardware with innovative design elements. It's one of the first universal laptop docking stations to support three external displays.
When coupled with your laptop display, the docking station makes it easy to create a high-performance, high-resolution workstation with four displays in total, including one 4K DisplayPort display.
With its expanded display presence, this specialty docking station is ideal for a wide range of applications. It offers a fast and easy way to maximize your laptop's workable screen space, which is perfect for graphic and web designers, animators, financial analysts and more.
The triple-video docking station uniquely integrates two video chipsets, making it possible to connect one HDMI and two DisplayPort monitors to your laptop. With four total displays, you can manage several programs at once and avoid the nuisance of minimizing or rearranging windows. Plus it delivers 4K cinema resolution to the first DisplayPort monitor.
This versatile docking station boosts your workflow with minimal impact on your budget, and it connects to your laptop or Windows based tablet through just one USB 3.0 (also known as USB 3.1 Gen 1 - 5Gbps) cable.
Why sacrifice image quality for display quantity? This top-of-the-line docking station offers the best of both worlds. It features three video ports, including a DisplayPort connection that supports 4K x 2K (3840 x 2160p - 30Hz) Ultra HD resolution.
The docking station offers an enhanced method of upgrading the display capabilities of your computer. While many laptop docks offer two video outputs, they often don't support three external displays, or Ultra High Definition.
The full-featured dock delivers crystal-clear image quality without sacrificing the total number of external monitor connections, which is ideal for highly detailed and graphically intense applications.
This triple-video docking station lets you connect up to 12 peripherals, to transform your laptop into a powerful, full-sized workstation.
The dock also makes it easy to quickly charge your mobile devices, using the always-on fast-charge port. Plus, with five USB 3.0 ports, a headset jack, separate 3.5mm audio and microphone ports, as well as an RJ45 Gigabit Ethernet port, you have all the connections you need with no complications or extra costs.
Unlike some docks, this easy-to-use docking station offers seamless, error-free driver installation that will have you up and running fast.
StarTech.com Triple Monitor USB 3.0 Laptop Docking Station - 4K HDMI, 2x DisplayPort - Universal USB Dock for Windows & Mac OS (USB3DOCKH2DP) - docking station
Docking station
Docking Interface
USB
Black & silver
Gigabit Ethernet
Power adapter AC 120/230 V
3-year warranty
P/N: ARMBARTRIO2, ARMTRIO, ARMUNONB
Docking station
Enclosure Colour
Black & silver
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
2 x display / video - 20 pin DisplayPort , 1 x display / video - 19 pin HDMI Type A , 5 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - RJ-45 , 1 x audio - mini-phone 3.5 mm 4-pole , 1 x microphone - mini-phone stereo 3.5 mm , 1 x headphones - mini-phone stereo 3.5 mm , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B
1 x SuperSpeed USB cable - external
Security lock slot (cable lock sold separately), LED indicator, UASP transfer protocol
FCC, RoHS, USB Battery Charging Specification Rev. 1.2
Power adapter
AC 120/230 V
Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.8 - 10.12, Google Chrome OS 55 or later, Apple macOS Mojave 10.14
Limited warranty - 3 years
StarTech.com Triple-Video Laptop Dock Bundle deal on StarTech.com Triple-Video Laptop Dock
£248.76
BM03 StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £7.46
BM03 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.69
BM03 StarTech.com 3.5mm 3 Pin Headset Splitter In Stock £6.42
BM03 StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £19.37
BM03 StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort In Stock £120.39
BM03 StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.41
BM03 StarTech.com Triple-Video Laptop Dock In Stock £149.59
BM03 StarTech.com Docking Station for 2 Laptops In Stock £156.24
BM03 StarTech.com 4K DP Laptop Docking Station In Stock £99.36
Price Range Ex VAT: 100 - 150
