StarTech.com Triple Monitor Desk Mount
Quicklinx: HVM3WS00 Mfr#: 3MP2AG-MONITOR-ARM
£178.05 ex VAT
£213.66 inc VAT
Enhance your workspace with the StarTech.com Triple Monitor Desk Mount, designed for up to three 27in screens. This mounting kit offers a range of adjustments including extension, pivot, swivel, and tilt, allowing users to find the perfect viewing angle for productivity and comfort. The spring-assisted arms make it easy to adjust the position of your screens without the need for tools, while the integrated cable management channel ensures your setup remains tidy and organized. Whether you prefer a C-clamp or grommet mount, this kit includes everything needed for a straightforward installation process. Constructed from high-quality aluminum, plastic, and steel, it provides a stable and durable solution for your multi-monitor setup. Elevate your desk and your work experience with this reliable and flexible monitor mount.
  • Flexible positioning
    With extension, pivot, swivel, and tilt adjustments, this triple monitor desk mount offers flexibility. Users can easily adjust their screens to the perfect angle, enhancing both comfort and productivity.
  • Effortless installation
    The toolless arm adjustments and a comprehensive package containing all necessary screws, washers, spacers, and hex keys make the assembly process straightforward. Whether opting for a C-clamp or grommet mount, setting up your workstation has never been easier.
  • Robust build quality
    Constructed from a combination of aluminum, plastic, and steel, this mounting kit is designed to securely hold three LCD displays up to 27 inches each. Its durable materials ensure long-term reliability and stability for your setup.
StarTech.com Triple Monitor Desk Mount For Up To Three 27in Screens, VESA 75x75/100x100, Tool-Less Arm Adjustments, C-Clamp/Grommet Mount, Spring-Assisted Arms mounting kit - adjustable arm - for 3 LCD displays - black
Mounting kit (adjustable arm) - desk-mountable
17.6 cm
Adjustable Height
22.5-56.2 cm
Tilt
-90° to 90°
Rotation
-90° to 90°
Swivel
-180° to 180°
Adjustments
Extension, rotation, swivel, tilt
7.7 kg
Recommended Use
3 LCD displays
Recommended Display Size
Up to 27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Material
Aluminium, steel, plastic
Package Content
2 x spring arm, 3 x VESA monitor mounts, 4 x swivel arms, pole, 12 x M4x12 screws, 12 x M4x16 screws, cable management clip, hex key (3mm), hex key (6mm), 12 x M5x12 screws, 12 x M5x16 screws, 12 x flat washers, 12 x spacers, desk clamp, shoulder pole mount, center pole mount, center monitor mount, tool holder, grommet clamp plate, grommet clamp screw
5-year warranty
17.6 cm
Adjustable Height
22.5-56.2 cm
7.7 kg
Material
Package Content
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
3 LCD displays
Placing / Mounting
Desk-mountable
Cable Management
Cable management channel
Up to 27"
Tilt
-90° to 90°
Rotation
-90° to 90°
Swivel
-180° to 180°
Adjustments
Assembly Required
Dimensions & Weight Details
55.5 cm x 39.5 cm x 11.5 cm / 8.9 kg
Limited warranty - 5 years
HVM3 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.54
HVM3 StarTech.com 24" Monitor Privacy Screen In Stock £79.81
HVM3 StarTech.com 27" Monitor Privacy Screen In Stock £101.53
HVM3 StarTech.com 25" Monitor Privacy Screen In Stock £71.91
