StarTech.com Triple-Monitor Arm - Steel
Quicklinx: CRY3WS00 Mfr#: ARMTRIO
Accessory Type: Mount
More than 50 In Stock
£144.45 ex VAT
£173.34 inc VAT
Save desk space by mounting three displays, with articulating arms to create a surround effect. Create the ultimate ergonomic comfort while freeing up valuable desk space with this triple-monitor arm. You can set up three computer monitors (each up to 24") and create a surround setup to maximize productivity. The triple-monitor arm works with all VESA mount compliant monitors including Acer, HP and Samsung.
Enhance your productivity and work in comfort with a multi-screen setup. The triple-monitor arm supports three displays (13" to 24") and lets you adjust the position of your monitors with 360° rotation and + 30° / -30° tilt for each monitor.
Choose from landscape or portrait screen rotation to customize your workspace. You can set up three displays in landscape position to create a curved surround effect or 'cockpit style' for comfortable viewing. This setup is ideal for editing videos or photos or working with multiple documents at the same time. For applications such as web design or coding, you may choose an alternate setup, for example with the center monitor in landscape mode and the outside monitors in portrait position.
Made of strong and durable steel, the triple-monitor stand securely supports three separate computer monitors up to 24" in size. It supports a weight capacity of up to 17.6 lb. or 8 kg for each monitor.
The triple-monitor arm is VESA mount compatible, working with most computer monitors up to 24". It's easy to set up using the included desk clamp or grommet mount and also comes with cable management clips to keep your cables neat and tidy.
You can adjust the display height without tools. You simply turn the adjustment knob to adjust the monitor height, keeping all three monitors at the same level.
  • Sturdy Construction
    The solid steel design ensures long-lasting stability and support for multiple monitors.
  • Flexible Viewing Angles
    With a tilt range of -30° to 30° and full 360° rotation, monitors can be adjusted for comfortable viewing.
  • Organized Workspace
    Integrated cable management keeps cords out of sight, contributing to a clean and uncluttered desk area.
  • Custom Height Adjustments
    Users can easily modify the height of monitors to promote ergonomic practices and reduce strain.
  • Versatile Monitor Compatibility
    Supports three displays, making it ideal for multitasking and enhancing overall work efficiency.
StarTech.com Desk Mount Triple Monitor Arm, Ergonomic VESA 3 Monitor Mount up to 27", Articulating & Height Adjustable Pole Mount, Tilt/Swivel/Rotate LCD/LED Screen, Desk Clamp/Grommet - Monitor Pole Mount (ARMTRIO) adjustable arm - for 3 monitors
Adjustable arm
Tilt
-30° to 30°
Rotation
360°
Adjustments
Recommended Use
3 monitors
Recommended Display Size
13"-27"
VESA Mounting Interface
Material
Solid steel
5-year warranty
P/N: DK30CH2DPPD, USB3DOCKH2DP
Material
Solid steel
AV Furniture
Adjustable arm
Recommended Use
3 monitors
Cable Management
13"-27"
Tilt
-30° to 30°
Rotation
360°
Adjustments
Limited warranty - 5 years
CRY3 StarTech.com Triple-Video Laptop Dock In Stock £91.54
CRY3 StarTech.com Triple Monitor Stand - Steel In Stock £169.33
CRY3 StarTech.com Thin Client Mount - VESA In Stock £23.04
CRY3 StarTech.com Under Desk Keyboard Tray In Stock £53.36
CRY3 StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £54.54
CRY3 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £61.12
CRY3 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.54
CRY3 StarTech.com Triple Monitor Desk Mount In Stock £178.05
CRY3 StarTech.com Triple Monitor Desk Mount In Stock £169.08
