Save desk space by mounting three displays, with articulating arms to create a surround effect. Create the ultimate ergonomic comfort while freeing up valuable desk space with this triple-monitor arm. You can set up three computer monitors (each up to 24") and create a surround setup to maximize productivity. The triple-monitor arm works with all VESA mount compliant monitors including Acer, HP and Samsung.
Enhance your productivity and work in comfort with a multi-screen setup. The triple-monitor arm supports three displays (13" to 24") and lets you adjust the position of your monitors with 360° rotation and + 30° / -30° tilt for each monitor.
Choose from landscape or portrait screen rotation to customize your workspace. You can set up three displays in landscape position to create a curved surround effect or 'cockpit style' for comfortable viewing. This setup is ideal for editing videos or photos or working with multiple documents at the same time. For applications such as web design or coding, you may choose an alternate setup, for example with the center monitor in landscape mode and the outside monitors in portrait position.
Made of strong and durable steel, the triple-monitor stand securely supports three separate computer monitors up to 24" in size. It supports a weight capacity of up to 17.6 lb. or 8 kg for each monitor.
The triple-monitor arm is VESA mount compatible, working with most computer monitors up to 24". It's easy to set up using the included desk clamp or grommet mount and also comes with cable management clips to keep your cables neat and tidy.
You can adjust the display height without tools. You simply turn the adjustment knob to adjust the monitor height, keeping all three monitors at the same level.
Sturdy Construction
The solid steel design ensures long-lasting stability and support for multiple monitors. -
Flexible Viewing Angles
With a tilt range of -30° to 30° and full 360° rotation, monitors can be adjusted for comfortable viewing. -
Organized Workspace
Integrated cable management keeps cords out of sight, contributing to a clean and uncluttered desk area. -
Custom Height Adjustments
Users can easily modify the height of monitors to promote ergonomic practices and reduce strain. -
Versatile Monitor Compatibility
Supports three displays, making it ideal for multitasking and enhancing overall work efficiency.
- Startech Desk Mount Triple Monitor Arm, Ergonomic VESA 3 Monitor Mount up to 27", Articulating & Height Adjustable Pole Mount, Tilt/Swivel/Rotate LCD/LED Screen, Desk Clamp/Grommet - Monitor Pole Mount (ARMTRIO) adjustable arm - for 3 monitors
- Product Type
- Adjustable arm
- Tilt
- -30° to 30°
- Rotation
- 360°
- Adjustments
- Recommended Use
- 3 monitors
- Recommended Display Size
- 13"-27"
- VESA Mounting Interface
- Material
- Solid steel
- 5-year warranty
- Designed For
- P/N: DK30CH2DPPD, USB3DOCKH2DP
- Material
- Solid steel
AV Furniture
- Adjustable arm
- Recommended Use
- 3 monitors
- Cable Management
- Integrated cable management
- 13"-27"
- Tilt
- -30° to 30°
- Rotation
- 360°
- Adjustments
- Limited warranty - 5 years
- Designed For
StarTech.com Triple-Video Laptop Dock | In Stock | £95.44 |
StarTech.com Desk Mount Quad Monitor Arm | In Stock | £175.53 |
StarTech.com Triple Monitor Stand - Steel | In Stock | £169.33 |
StarTech.com Thin Client Mount - VESA | In Stock | £22.53 |
StarTech.com Under Desk Keyboard Tray | In Stock | £55.81 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £53.32 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £59.75 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £77.01 |
StarTech.com Triple Monitor Desk Mount | In Stock | £178.05 |
StarTech.com Triple Monitor Desk Mount | In Stock | £167.93 |
