The SP123DP Triple Head DisplayPort Multi Monitor Graphics Expansion Module/Adapter is an external multi-monitor spanner/splitter that lets you add multiple displays (up to three) to a desktop or laptop PC, from a single DisplayPort source.
This versatile graphics expansion module enables you to combine 3 DisplayPort monitors as a single display, for a panoramic multi-display setup at resolutions up to 3840x1024 - all without opening the computer case. The expansion module also lets you clone (mirror) your primary display, using the device as a 3-port DisplayPort splitter.
Compatible with a DisplayPort video card and displays, the graphics expansion module requires no software installation for multi-display applications, simplifying configuration and saving time.
- StarTech.com Triple Head DisplayPort Multi Monitor Adapter - video splitter - 3 ports
- Video splitter - 3 ports
- Power
- AC 100/230 V
- 6.5 cm x 13.1 cm x 2.6 cm
- 270 g
- Black
- 2-year warranty
- Designed For
- P/N: SVA5N3NEUA
- Enclosure Type
- Desktop
- Max Resolution
- 3840 x 1200
- Status Indicators
- Power
- Display / video: 3 x DisplayPort output - 20 pin DisplayPort , Display / video: 1 x DisplayPort input - 20 pin DisplayPort
- Power Device
- External power adapter
- Voltage Required
- AC 100/230 V
- Black
- FCC, RoHS
- 6.5 cm
- 13.1 cm
- 2.6 cm
- 270 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- Designed For
- P/N: SVA5N3NEUA
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £23.98 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.12 |
StarTech.com DisplayPort to DVI Active Adapter | In Stock | £22.91 |
