StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI
Quicklinx: 9KZDWS00 Mfr#: MDP2VGDVHDW
49 in stock
£32.61 ex VAT
£39.13 inc VAT
Connect a Mini DisplayPort-equipped PC or Mac to an HDMI, VGA, or DVI Display. The MDP2VGDVHDW Mini DisplayPort to VGA, DVI or HDMI converter offers a three-in-one solution for connecting an mDP source such as a Thunderbolt -enabled MacBook Pro / MacBook Air to a VGA, DVI, or HDMI Display. Ensuring compatibility with almost any display, television or projector, this compact and lightweight adapter offers the ideal plug-and-play solution for travel, or BYOD (Bring Your Own Device) applications around the office.
You can walk into any boardroom and be ready to connect, even if you don't know what connection ports are available. The MDP2VGDVHDW maximizes the audio/video connectivity of your MacBook by offering three different output ports, in a single compact adapter.
The three-in-one converter is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. Plus, because the converter cable supports video resolutions up to 1920x1200/1080p you can convert a Mini DisplayPort video source to VGA, HDMI, or DVI without sacrificing video quality.
The Mini DisplayPort converter requires no power adapter and maximizes portability by easily traveling in your laptop bag with a small footprint and lightweight design.
The MDP2VGDVHDW features a sleek white design that looks great next to your MacBook Pro or MacBook Air.
StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI - video converter - white
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x DVI-D output - 24+1 pin digital DVI
10 cm x 4.5 cm x 1.5 cm
Enclosure Colour
White
3-year warranty
Apple MacBook Air; MacBook Pro
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x DVI-D output - 24+1 pin digital DVI - female
FCC, RoHS
10 cm
4.5 cm
1.5 cm
51 g
Enclosure Colour
White
Limited warranty - 3 years
70 °C
10 - 85%
Apple MacBook Air , Apple MacBook Pro
9KZD StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
9KZD StarTech.com 6 ft DVI-D Single Link Cable - M/M In Stock £6.77
9KZD StarTech.com 15 ft DVI-D Single Link Cable - M/M In Stock £13.55
9KZD StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.62
9KZD StarTech.com 18in DVI-D Single Link Cable - M/M In Stock £4.97
9KZD StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M In Stock £9.79
9KZD StarTech.com 10 ft DVI-D Single Link Cable - M/M In Stock £7.89
9KZD StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £18.91
9KZD StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.14
9KZD StarTech.com 10m (33 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable In Stock £49.91
9KZD StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.02
9KZD StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £32.61
9KZD StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £32.61
9KZD StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI In Stock £32.61
9KZD StarTech.com mDP to HDMI or VGA Converter In Stock £17.92
9KZD StarTech.com mDP to HDMI or VGA Converter In Stock £13.32
9KZD StarTech.com DP to HDMI or VGA Converter In Stock £15.28
9KZD StarTech.com mini DisplayPort to VGA DVI or HDMI Adapter In Stock £40.96
Price Range Ex VAT: 0 - 50
