Install two 2.5" solid-state drives or hard drives into a single 3.5" bay in a desktop computer. Install your drives in no time - with no tools required. This tool-less mounting bracket lets you mount two 2.5" solid-state drives or hard drives into a 3.5" bay in your desktop computer.
The bracket design lets you quickly secure your drives into the mounting bracket, without using tools. Then you simply put the bracket into a 3.5" drive bay in your computer and hold it in place using the tool-less pegs.
Designed for versatility, the tool-less mounting bracket supports a wide range of 2.5" solid-state drives or hard drives, ranging from 5 to 12.5 mm in height.
The lightweight mounting bracket is designed for trouble-free, reliable performance.
- StarTech.com Dual 2.5" SSD/HDD Mounting Bracket for 3.5" Drive Bay - Tool-Less Installation - 2-Drive Adapter Bracket for Desktop Computer (BRACKET225PT) - storage bay adapter
- Storage bay adapter
- Black
- Supported Form Factor
- 3.5" to 2 x 2.5"
- Expansion Bays
- 2 x internal - 2.5"
- Compatible Bay
- 1 3.5"
- Product Material
- Plastic
- 13.2 cm x 10 cm x 2.95 cm
- 52 g
- 2-year warranty
- Designed For
- P/N: M2E4SFF8643, PEX4SFF8643, U2M2E125
- 3.5" to 2 x 2.5"
- Hard Drive Maximum Height
- 12.5 mm
- Product Material
- Plastic
- Black
Storage Controller
- Processor
- No CPU
- Bays
- Compatible Bay
- 1 x internal 3.5"
- Mounting Kit
- Included
- RoHS
- Limited warranty - 2 years
- 13.2 cm
- 10 cm
- 2.95 cm
- 52 g
- Designed For
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.42 |
StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay | In Stock | £2.95 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.06 |
StarTech.com 12in Latching SATA Cable | In Stock | £5.50 |
StarTech.com 18in Latching SATA Cable | In Stock | £3.89 |
StarTech.com 24in Latching SATA Cable | In Stock | £6.76 |
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £5.45 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £7.04 |
StarTech.com 6in Latching SATA Cable | In Stock | £2.61 |
StarTech.com 4x SATA Power Splitter Adapter Cable | In Stock | £6.36 |
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket | In Stock | £7.12 |
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm | In Stock | £19.99 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £15.54 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £17.99 |
StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter | In Stock | £14.65 |
StarTech.com M.2 NGFF to SATA Adapter | In Stock | £20.24 |
StarTech.com Tool-Less 2B Mounting Bracket | In Stock | £6.47 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £7.04 |
StarTech.com 2.5" SSD/HDD Mounting Bracket | In Stock | £4.21 |
StarTech.com 2.5 to 3.5 Hard Drive Adapter | In Stock | £22.96 |
StarTech.com 5 Pack - 2.5" SSD / HDD Mounting Bracket for 3.5" Drive Bay | In Stock | £16.09 |
StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter | In Stock | £13.51 |
