StarTech.com Tool-Less 2B Mounting Bracket
Quicklinx: BMPRWS00 Mfr#: BRACKET225PT
Hurry, only 3 left in stock!
£6.49 ex VAT
£7.78 inc VAT
Install two 2.5" solid-state drives or hard drives into a single 3.5" bay in a desktop computer. Install your drives in no time - with no tools required. This tool-less mounting bracket lets you mount two 2.5" solid-state drives or hard drives into a 3.5" bay in your desktop computer.
The bracket design lets you quickly secure your drives into the mounting bracket, without using tools. Then you simply put the bracket into a 3.5" drive bay in your computer and hold it in place using the tool-less pegs.
Designed for versatility, the tool-less mounting bracket supports a wide range of 2.5" solid-state drives or hard drives, ranging from 5 to 12.5 mm in height.
The lightweight mounting bracket is designed for trouble-free, reliable performance.
StarTech.com Dual 2.5" SSD/HDD Mounting Bracket for 3.5" Drive Bay - Tool-Less Installation - 2-Drive Adapter Bracket for Desktop Computer (BRACKET225PT) - storage bay adapter
Storage bay adapter
Supported Form Factor
3.5" to 2 x 2.5"
Expansion Bays
2 x internal - 2.5"
Compatible Bay
1 3.5"
Product Material
Plastic
13.2 cm x 10 cm x 2.95 cm
52 g
P/N: M2E4SFF8643, PEX4SFF8643, U2M2E125
Storage bay adapter
3.5" to 2 x 2.5"
Hard Drive Maximum Height
12.5 mm
Product Material
Plastic
Storage Controller
No CPU
Bays
2 x internal - 2.5"
Compatible Bay
1 x internal 3.5"
Mounting Kit
Included
RoHS
13.2 cm
10 cm
2.95 cm
52 g
BMPR StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
BMPR StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay In Stock £3.02
BMPR StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.48
BMPR StarTech.com 12in Latching SATA Cable In Stock £6.16
BMPR StarTech.com 18in Latching SATA Cable In Stock £4.24
BMPR StarTech.com 24in Latching SATA Cable In Stock £6.84
BMPR StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.88
BMPR StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £6.34
BMPR StarTech.com 6in Latching SATA Cable In Stock £2.60
BMPR StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter In Stock £13.55
BMPR StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £29.96
BMPR StarTech.com 4x SATA Power Splitter Adapter Cable In Stock £6.60
BMPR StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.24
BMPR StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm In Stock £20.49
BMPR StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.57
BMPR StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.13
BMPR StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £14.65
BMPR StarTech.com Tool-Less 2B Mounting Bracket In Stock £6.49
BMPR StarTech.com 6" SATA Power Y Splitter Cable In Stock £6.34
BMPR StarTech.com 2.5" SSD/HDD Mounting Bracket In Stock £4.64
BMPR StarTech.com 2.5 to 3.5 Hard Drive Adapter In Stock £23.17
BMPR StarTech.com 5 Pack - 2.5" SSD / HDD Mounting Bracket for 3.5" Drive Bay In Stock £16.49
