StarTech.com Thunderbolt to GbE + USB 3
Quicklinx: 9ZR9WS00 Mfr#: TB2USB3GE
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Add a Gigabit Ethernet port and a USB 3.0 hub port to your Thunderbolt -equipped MacBook or Ultrabook . The TB2USB3GE Thunderbolt to Gigabit Ethernet + USB 3.0 Adapter lets you expand your MacBook or laptop connectivity through a single, compact adapter with both Gigabit Ethernet and USB 3.0, delivering reliable performance, connection possibilities and rugged portability.
Experience fast, effective and reliable performance from your essential peripherals! Leveraging the 10Gbps bandwidth of your Thunderbolt port for this dual-purpose adapter gives you reliable 1Gbps Ethernet and 5Gbps USB 3.0 connectivity, while enabling you to use both to their full capacity.
To maximize efficiency, the Thunderbolt adapter separates traffic from each interface into its own dedicated 5Gbps PCI Express lane, effectively avoiding bottlenecks when both ports are in use. This practical adapter gives you fast, robust external connectivity, offered by revolutionary Thunderbolt technology.
Take full advantage of your current peripherals! Saving you the added expense of purchasing new devices, the adapter lets you simultaneously connect your existing devices through your Thunderbolt port. Combining Thunderbolt to Ethernet and Thunderbolt to USB 3.0 functionality into a single adapter gives you two essential interfaces that are unavailable or limited on most Thunderbolt-equipped systems, making it easy for business users and home users alike to stay connected.
Whether you're in a boardroom with a weak WiFi signal, or in a hotel with only a wired network connection, this adapter has you covered. Plus, the USB 3.0 port (with UASP support) can be used to connect a storage device, USB hub, USB printer, or sync with your tablet or smartphone.
Get work done on the go, and look great doing it! A rugged and travel-friendly design lets you tuck the adapter neatly into your laptop bag, plus the lightweight casing merges portability with durability to offer quality protection that lets you take the adapter anywhere.
The sleek and stylish adapter aesthetically matches your MacBook Pro or MacBook Air, with a silver sandblast finish and black rubberized grips. Plus, the compact adapter requires no external power, and integrates a built-in Thunderbolt cable as well as hassle-free plug-and-play installation.
  • Fast, reliable performance
    Experience fast, effective and reliable performance from your essential peripherals! Leveraging the 10 Gbps bandwidth of your Thunderbolt port for this dual-purpose adapter gives you reliable 1 Gbps Ethernet and 5 Gbps USB 3.0 connectivity, while enabling you to use both to their full capacity. To maximize efficiency, the Thunderbolt adapter separates traffic from each interface into its own dedicated 5 Gbps PCI Express lane, effectively avoiding bottlenecks when both ports are in use. This practical adapter gives you fast, robust external connectivity, offered by revolutionary Thunderbolt technology.
  • Connection possibilities
    Take full advantage of your current peripherals! Saving you the added expense of purchasing devices, the adapter lets you simultaneously connect your existing devices through your Thunderbolt port. Combining Thunderbolt to Ethernet and Thunderbolt to USB 3.0 functionality into a single adapter gives you two essential interfaces that are unavailable or limited on most Thunderbolt-equipped systems, making it easy for business users and home users alike to stay connected. Whether you're in a boardroom with a weak Wi-Fi signal, or in a hotel with only a wired network connection, this adapter has you covered. Plus, the USB 3.0 port (with UASP support) can be used to connect a storage device, USB hub, USB printer, or sync with your tablet or smartphone.
  • Rugged portability
    Get work done on the go, and look great doing it! A rugged and travel-friendly design lets you tuck the adapter neatly into your laptop bag, plus the lightweight casing merges portability with durability to offer quality protection that lets you take the adapter anywhere. The sleek and stylish adapter aesthetically matches your MacBook Pro or MacBook Air, with a silver sandblast finish and black rubberized grips. Plus, the compact adapter requires no external power, and integrates a built-in Thunderbolt cable as well as hassle-free plug-and-play installation.
StarTech.com Thunderbolt to Gigabit Ethernet plus USB 3.0 - Thunderbolt Adapter - Thunderbolt to Ethernet - Thunderbolt to USB 3.0 (TB2USB3GE) - network adapter - Thunderbolt - Gigabit Ethernet + USB 3.0
Network adapter
External
Interface (Bus) Type
Thunderbolt
Ports
8.1 cm x 4.85 cm x 2.05 cm
92 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, USB, 100Mb LAN, 1GbE, USB 2.0, USB 3.0
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Silver
Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.8.4 or later, Windows 10 (32/64 bits)
Network adapter
External
Thunderbolt
Ports
Wired
Cabling Type
Ethernet, USB, Fast Ethernet, Gigabit Ethernet, USB 2.0, SuperSpeed USB 3.0
Status Indicators
Link OK, link/activity
Flow control, full duplex capability, auto-uplink (auto MDI/MDI-X), Jumbo Frames support, Energy Efficient Ethernet
1 x 1000Base-T - RJ-45 - female , 1 x USB 3.0 - 9 pin USB Type A - female
1 x Thunderbolt cable (integrated) - 13 cm
FCC, RoHS
Silver
8.1 cm
4.85 cm
2.05 cm
92 g
-10 °C
55 °C
9ZR9 StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White In Stock £37.08
9ZR9 StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black In Stock £29.25
