StarTech.com Thunderbolt Docking Station - HDMI Mini DisplayPort USB 3.0 GbE w/ Thunderbolt Cable
Quicklinx: 95XPWS00 Mfr#: TBDOCKHDPBC
Transform your MacBook into a powerful home / office workstation through a single Thunderbolt cable. The TBDOCKHDPBC Thunderbolt Docking Station gives you a single connection point to your home / office workstation, for a flexible setup with formidable speed. Adding Thunderbolt and HDMI video outputs, Gigabit Ethernet, a USB 3.0 hub and 3.5mm audio ports to your Thunderbolt-equipped laptop has never been easier.
Start working faster! The Thunderbolt dock reduces the hassle of connecting a typical laptop workstation by leaving your entire peripheral set connected to the dock. Through a single connection to your laptop (e.g. MacBook Pro, MacBook Air or Ultrabook), you can be up-and-running in seconds.
Get connected right away with the included high-quality 1m Thunderbolt cable, saving you time and money.
Experience a tidy and customizable workspace with a small footprint and included optional stand, so you can place the Thunderbolt dock either horizontally or vertically.
Connect more of your USB peripherals through the integrated 3-port USB 3.0 controller. External USB 3.0 hard drives benefit from the smooth response and faster data transfer rates provided by UASP. Older USB peripherals aren't a problem either, with USB 2.0/1.1 backward-compatibility.
Increase your overall system performance with a dedicated controller for onboard I/O handling, freeing up system resources. With data transfer rates up to 10 Gbps, Thunderbolt technology simultaneously supports a high-resolution display and high-performance data devices through a single interface, plus you can daisy-chain up to 6 devices (Thunderbolt 1 and 2 compatible) for maximum connectivity.
Expand your screen real estate and increase productivity, using the integrated monitor outputs. With support for resolutions up to 1920x1080 (HDMI) and 2560x1440 (Thunderbolt / Mini DisplayPort), the dock provides several options to add external HD displays.
When using a single display, the dock lets you connect one HDMI, DisplayPort or Thunderbolt monitor. The Thunderbolt interface on the dock is backward compatible with Mini DisplayPort and when connected to a DisplayPort monitor, only a single display can be added as HDMI will be disabled. For dual display configurations, you can connect one HDMI monitor and one Thunderbolt monitor simultaneously.
StarTech.com Thunderbolt Laptop Docking Station - HDMI / MDP w/ 1m TB Cable - docking station - Thunderbolt - 2 x Mini DP - 1GbE
Docking station
Docking Interface
Thunderbolt
Video Interfaces
2 x Mini DP
9.85 cm x 18.45 cm x 7 cm
500 g
Black & silver
Gigabit Ethernet
Power adapter - external AC 100/230 V
3-year warranty
P/N: ARMPIVOT, ARMPIVOTE, ARMPIVSTND, ARMSLIM, ARMUNONB, TBLT3MM1MA, TBLT3MM2M, TBLT3MM2MA
Docking station
9.85 cm
18.45 cm
7 cm
500 g
Enclosure Colour
Black & silver
Gigabit Ethernet
3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-TX - RJ-45 , 2 x Thunderbolt - Mini DisplayPort , 1 x audio - line-out - mini-phone stereo 3.5 mm , 1 x microphone - input - mini-phone 3.5 mm
1 x Thunderbolt cable - external - 1 m
Rubber feet, stand
AC 100/230 V
Apple MacOS X 10.8.3 or later, Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits), Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
Limited warranty - 3 years
5 °C
