StarTech.com Thunderbolt 4 Dock, 96W PD
Quicklinx: GXJWWS00 Mfr#: TB4CDOCKUE
Device Type: Laptop, Macbook
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black, Grey
26 In Stock
£147.95 ex VAT
£177.54 inc VAT
COMPATIBILITY: Features 3x downstream Thunderbolt 4 (40Gbps) ports to connect TB4, TB3, USB4 & USB 3.2 peripherals & display(s); Compatible w/Windows Thunderbolt 4/USB4 laptops or M1 Max/M1 Pro & Intel Thunderbolt 3 MacBooks (macOS 11 Big Sur or higher).
CERTIFIED 96W POWER DELIVERY: Charge most laptops including high performance MacBooks and Thunderbolt 4/USB4 Windows laptops; Downstream TB4/USB4 ports support 15W (3A) charging; 1x BC 1.2 USB-A port with 7.5W (1.5A) for charging tablets & smartphones.
PORT FLEXIBILITY: 3x TB4 ports for peripherals, up to 2 extended displays (w/USB-C video adapters), daisy chain up to 5 devices; 4x USB-A ports (3x 10Gbps/1x BC 1.2 fast charge); SD 4.0 card reader; Gigabit Ethernet (w/PXE Boot/WoL); 3.5mm headset port.
DISPLAY COMPATIBILITY: Up to single 8K30Hz/6K60Hz/5K60Hz or dual monitors at 4K60Hz on Thunderbolt 4 or USB4 Windows laptops supporting multiple monitors | Single 4K/5K/6K60Hz on M1 MacBooks | Dual 4K60Hz/Single 5K/6K on TB3 Intel/TB4 M1 Pro/Max MacBooks.
THUNDERBOLT CERTIFIED: Fully compatible w/Intel Evo, Tiger Lake (11th gen) & up TB4 laptops (Dell Precision 5560/5760, XPS 13 9310, HP EliteBook 850 G8, ProBook 450 G8, Lenovo X1 Carbon 9th Gen); Also compatible w/M1/M1 Max/Pro & TB3 MacBooks (11.0 & up).
EASY DEPLOYMENT: Dock includes 2.6 ft (0.8 m) Thunderbolt 4 cable; Front host port; Kensington-style security slots; Auto driver setup.
CONNECTIVITY TOOLS: Provided with this device, the application improves performance and security, featuring MAC Address Changer, USB Event Monitoring, Windows Layout & Wi-Fi Auto Switch utilities
  • High-Performance Port Connectivity
    The docking station utilizes the high 40Gbps throughput available from your computer's Thunderbolt 4, Thunderbolt 3, or USB4 port to provide a wide range of port connectivity to suit a variety of applications, including daisy chaining up to five devices from the TB4/USB4 ports. The dock features: • 3x downstream Thunderbolt 4/USB4 ports to flexibility connect Thunderbolt 4, Thunderbolt 3, and USB peripheral devices and display(s), with the added benefit of 15W (3A) device charging per each port. • 3x USB 3.2 Gen 2 (10Gbps) Type-A ports to connect USB peripheral devices. • 1x USB 2.0 (480Mbps) Type-A port that supports BC 1.2 with 7.5W (1.5A) for charging tablets and smartphones, or connecting USB Human Interface Device(s) (HID), such as a USB transceiver, to minimize signal interference. • 1x Gigabit Ethernet port with PXE boot and WoL to connect to a wired Local Area Network (LAN). • 1x Secure Digital (SD) 4.0/UHS-II card reader to externally access SD, SDHC and SDXC memory cards. • 1x 3.5mm 4-position TRRS Audio Jack to connect a 3.5mm headset.
  • High-Resolution Display Connectivity
    Up to two monitors can be attached to any of the downstream Thunderbolt 4 ports using USB-C monitors, Thunderbolt monitors or USB-C DP Alt Mode to video adapters (video adapter required, each sold separately). On Thunderbolt 4 Windows laptops the dock can support dual monitors with resolutions up to 4K 60Hz, or a single monitor with resolutions up to 8K 30Hz, 6K 60Hz, 5K 60Hz, 4K 60Hz. On Thunderbolt 4 M1 Max and M1 Pro MacBooks the dock can support dual monitors with resolutions up to 4K 60Hz, or a single monitor with resolutions up to 6K 60Hz, 5K 60Hz, 4K 60Hz. On M1 Thunderbolt 3 MacBooks the dock can support a single monitor with resolutions up to 6K 60Hz, 5K 60Hz, 4K 60Hz. On Intel Thunderbolt 3 MacBooks the dock can support dual monitors with resolutions up to 4K 60Hz, or a single monitor with resolutions up to 6K 60Hz, 5K 60Hz, 4K 60Hz. On USB4 Windows laptops the dock can support a single monitor with resolutions up to 8K 30Hz, 6K 60Hz, 5K 60Hz, 4K 60Hz.
  • 96W USB Power Delivery Certified
    The Thunderbolt 4 docking station includes a 135W power adapter and supports 96W USB power delivery. This enables the dock to charge your MacBooks and Thunderbolt 4 and USB4 Windows laptops. Plus, the added power provides downstream TB4/USB4 ports with 15W (3A) for device charging, and enables one of the USB-A ports to support BC 1.2, for charging tablets and smartphones.
  • Thunderbolt Certified
    To ensure compatibility with your Thunderbolt 4 computers and Thunderbolt 4/3 peripheral devices. This certification provides assurance the dock will be fully compatible with Intel Evo/Tiger Lake (11th gen & up) Thunderbolt 4 laptops including: Dell Precision 5560/5760, XPS 13 9310, HP EliteBook 850 G8, ProBook 450 G8, and Lenovo X1 Carbon 9th Gen. The dock is also compatible with M1 & Intel Thunderbolt 3 MacBooks (11.0 & up).
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN. Note: • The docking station is compatible with Thunderbolt 4/USB4 Windows laptops, Thunderbolt 4 M1 Max/M1 Pro MacBooks, and Thunderbolt 3 M1/Intel MacBooks (macOS 11 Big Sur or higher). • USB4 Windows laptops may support dual-displays over Thunderbolt if supported by the USB4 Windows Laptop.
StarTech.com Thunderbolt 4 Dock, 96W Power Delivery, Single 8K/Dual Monitor 4K 60Hz, 3xTB4/USB4 ports, 4xUSB-A, SD, GbE, Thunderbolt 4 Docking Station for Windows or TB3 MacBook, 0.8m - docking station - Thunderbolt 4 - 3 x Thunderbolt - 1GbE
Docking station
Docking Interface
Thunderbolt 4
Video Interfaces
3 x Thunderbolt
19.4 cm x 8.4 cm x 2.9 cm
1 kg
Black, grey
North America
Gigabit Ethernet
Power adapter AC 100-240 V
3-year warranty
Docking station
19.4 cm
8.4 cm
2.9 cm
1 kg
Enclosure Colour
Black, grey
North America
Video
Max Resolution Details
4K - 60 Hz (Dual Display) , 8K - 30 Hz (Single Display) , 5K - 60 Hz (Single Display) , 6K - 60 Hz (Single Display)
USB 3.2, USB 2.0
Expansion Slots
1 (total) / 1 (free) x SD / MMC Memory Card
1 x USB 2.0 with Battery Charging 1.2 (7.5 W) - 4 pin USB Type A , 3 x USB 3.2 Gen 2 - 9 pin USB Type A , 3 x Thunderbolt 4 - 24 pin USB-C , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio - headphones/microphone - mini-phone stereo 3.5 mm 4-pole , 1 x Thunderbolt 4 with Power Delivery (96W) - 24 pin USB-C
Input Device
microSD card reader, SD card reader, MMC card reader
1 x Thunderbolt 4 cable - external - 80 cm
96W power delivery, wake on LAN, Preboot Execution Environment (PXE) support, security lock slot (cable lock sold separately), mini security lock slot (cable lock sold separately), LED indicator, auto MDIX support, full duplex support, aluminium/plastic enclosure
Security Slot Type
Kensington security slot
USB Battery Charging Specification Rev. 1.2, RoHS
Power adapter
AC 100-240 V
Microsoft Windows 10 / 11, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0
Limited warranty - 3 years
Shipping Width
23.5 cm
Shipping Depth
14.5 cm
Shipping Height
9 cm
Shipping Weight
1.1 kg
50 °C
GXJW StarTech.com USB-C to DisplayPort Adapter In Stock £22.62
GXJW StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.04
GXJW StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £23.05
GXJW StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter In Stock £20.32
Device Type: Laptop
Device Type: Macbook
Colour: Black
Colour: Grey
