This Thunderbolt 3 to eSATA and USB 3.1 adapter lets you expand the connectivity of your Mac or PC laptop, by adding two essential ports. Simply connect it to the Thunderbolt 3 port on your laptop to provide an eSATA port and a USB 3.1 (10 Gbps) port. Compact and portable, it's the perfect companion for your MacBook Pro or any other Thunderbolt 3 equipped laptop.
Connect to your existing eSATA devices
Extend the life of your external storage devices. Using the adapter's eSATA port, simply connect an eSATA-equipped external hard drive, solid-state drive or external enclosure. -
Connect to USB 3.1 (10 Gbps) devices
The adapter lets you add any USB 3.1 or USB 3.0 device, such as an external hard drive, SSD or flash drive. It's also backward compatible with USB 2.0 devices. -
Fast, reliable performance
Leverage your Thunderbolt 3 port to create a high-speed solution that offers both eSATA and USB 3.1 connectivity. To maximize performance efficiency, two dedicated lanes connect the Thunderbolt adapter directly to your system PCIe bus. Both ports on the adapter deliver full bandwidth, so you avoid performance bottlenecks when the two ports are in use. -
Rugged portability
Its compact and durable housing makes the adapter ideal for portable use. It requires no external power, and features an integrated Thunderbolt cable. Setting the adapter up is easy, with Plug-and-Play installation.
 - StarTech.com Thunderbolt 3 to eSATA Adapter with USB 3.1 (10Gbps) - USB C to USB Adapter - Thunderbolt 3 to USB 3.0 Hub (TB3ESATU31) - storage controller - USB 3.1 Gen 2 / eSATA 6Gb/s - Thunderbolt
 - Storage controller - external
- Bus Type
 - Thunderbolt
 - Black & silver
- Interface
- Data Transfer Rate
 - 10 GBps
- Product Material
 - Plastic
- System Requirements
 - Apple macOS 10.12, Apple macOS 10.13, Apple macOS 10.14, Apple macOS 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
 - 5.2 cm x 24 cm x 2.12 cm
 - 53 g
 - 2-year warranty
- Designed For
 - P/N: TB3DK2DPM2, TB3DOCK2DPPD, TB3DOCK2DPPU
- Host Bus
 - Thunderbolt
- Product Material
 - Plastic
 - Black & silver
Storage Controller
- Interface
 - 10 GBps
- Processor
 - ASMedia ASM1061
 - 1 x USB 3.1 (Gen 2) - USB Type A , 1 x eSATA 6Gb/s - eSATA
- Connections
 - 1 x Thunderbolt input - 24 pin USB-C
- Cables Included
 - 1 x Thunderbolt cable - integrated - 16 cm
 - FCC, RoHS, RCM
- OS Required
 - Limited warranty - 2 years
 - 5.2 cm
 - 24 cm
 - 2.12 cm
 - 53 g
 - 0 °C
 - 40 °C
 - 40 - 50%
- Designed For
