StarTech.com Thunderbolt 3 to Dual DisplayPort Adapter DP 1.4 - Dual 4K 60Hz or Single 8K/5K
Quicklinx: G11CWS00 Mfr#: TB32DP14
£31.29 ex VAT
£37.54 inc VAT
DisplayPort 1.4 Video Splitter HBR3 Adapter HDR 2 x 4K 60Hz Mac & Windows . This high-performance Thunderbolt 3 to dual DisplayPort adapter lets you add two 4K 60Hz DP monitors to your Windows or MacBook computer through a single Thunderbolt 3 port, or it can be used to connect your TB3 port to an 8K display. The adapter features a built-in extended 18 inch (46 cm) cable that provides you with more flexibility when setting up your workstation.
Incredible 8K Picture Quality
Supporting four times the resolution of 4K, this 8K DisplayPort 1.4 adapter delivers the stunning quality of UHD at resolutions up to 7680×4320 on a single monitor and supports multi-display applications at lower resolutions and refresh rates (2 x 4K 60Hz), making it a great addition to your home, office or other work environments, while future-proofing for 8K implementation.
The adapter also features HBR3 functionality and with HDR support, you can enjoy lifelike images with increased contrast, brightness and colors.
Won't Drain Your Resources
This DP 1.4 multi-display adapter helps to keep your system running at peak performance. Unlike USB external video solutions, Thunderbolt 3 lets you run Ultra HD resolutions on both displays without draining system resources.
Ideal for On-the-Go Use
This lightweight video adapter is highly portable, with a small-footprint design. It fits perfectly in your carrying case, making it a great accessory for your MacBook or other Thunderbolt 3 device, especially when you're working away from the office.
TB32DP14 is backed by a StarTech.com 3-year warranty and free lifetime technical support.
  • Incredible 8K Picture Quality
    Supporting four times the resolution of 4K, this 8K DisplayPort 1.4 adapter delivers the stunning quality of UHD at resolutions up to 7680×4320 on a single monitor and supports multi-display applications at lower resolutions and refresh rates (2 x 4K 60Hz), making it a great addition to your home, office or other work environments, while future-proofing for 8K implementation. The adapter also features HBR3 functionality and with HDR support, you can enjoy lifelike images with increased contrast, brightness and colors.
  • Won't Drain Your Resources
  • Ideal for On-the-Go Use
    This lightweight video adapter is highly portable, with a small-footprint design. It fits perfectly in your carrying case, making it a great accessory for your MacBook or other Thunderbolt 3 device, especially when you're working away from the office. TB32DP14 is backed by a StarTech.com 3-year warranty and free lifetime technical support.
StarTech.com Thunderbolt 3 to Dual DisplayPort Adapter DP 1.4, Dual 4K 60Hz or Single 8K/5K Thunderbolt 3 to DP Adapter, TB3 to 2x DisplayPort Monitor Video Display Adapter, Mac/Windows - TB3 to DP 1.4 Adapter - USB / DisplayPort adapter - 24 pin USB-C to DisplayPort - 46 cm
8K support, HDR support, HBR3 support, Display Stream Compression 1.2 (DSC), HDCP compliant
Length
46 cm
Connector
24 pin USB-C - male (input)
Connector (Second End)
2 x 20 pin DisplayPort - female (output)
Thunderbolt 3 / DisplayPort 1.4
Silver
3-year warranty
Length
46 cm
Silver
6.44 cm
9.9 cm
1.6 cm
138 g
Connector
Thunderbolt 3 / DisplayPort 1.4, HDCP 2.2, RoHS, HDCP 1.4, REACH, FCC, WEEE
Shipping Width
11.2 cm
Shipping Depth
20.3 cm
Shipping Height
3.2 cm
Shipping Weight
300 g
3-year warranty
G11C StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £21.02
G11C StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.08
G11C StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
G11C StarTech.com DisplayPort to DVI Active Adapter In Stock £21.34
G11C StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £14.91
G11C StarTech.com DP to VGA Adapter with Audio In Stock £19.30
G11C StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £21.76
G11C StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £6.89
G11C StarTech.com 2m 6.6ft DisplayPort 1.4 Cable In Stock £11.86
G11C StarTech.com 3m 9.8ft DisplayPort 1.4 Cable In Stock £23.75
G11C StarTech.com 5m DisplayPort 1.4 Cable In Stock £30.35
G11C StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.78
