StarTech.com Thunderbolt 3 PCIe External
Quicklinx: HHWZWS00 Mfr#: 2TBT3-PCIE-ENCLOSURE
Type: System bus extender
Interface: USB 3.1 Type C
Speed: [N/A]
Ports: 3
Form Factor: External
Hurry, only 2 left in stock!
£518.57 ex VAT
£622.28 inc VAT
Add two PCI-Express 3.0 x16 capable cards and increase the potential of a Thunderbolt 3 or 4 capable laptop, desktop, or all-in-one system. This Thunderbolt 3 PCIe Expansion Chassis lets you take advantage of the vast range of PCIe expansion cards with computers that lack PCIe slots. The chassis lets you connect an external monitor via the DisplayPort (DP) or Thunderbolt 3 ports, supporting Ultra High Definition (UHD) 4K or 8K resolutions.
  • Enhanced Computer Capabilities
    Connect the expansion box to a Thunderbolt 3 or 4 computer with the included 3.3ft (1m) Thunderbolt-certified cable. The chassis features dual PCIe 3.0 x16 slots with 32Gbps of bandwidth that is shared dynamically between both slots (each slot supports up to 2700MBps/21.6Gbps). Add extra functionality to a host device using video capture cards, high-speed fiber or Ethernet networking, NVMe drives, FireWire, sound cards, or any other PCIe-compatible card.
  • Flexible Card Support
    The expansions chassis supports single-slot cards to a maximum length of 8in (20.3cm), allowing current or legacy PCIe cards to be installed. The built-in fan ensures active cooling for your hardware, preventing overheating during heavy usage. The TAA-Compliant chassis delivers up to 25W per slot, ensuring optimal performance for your connected devices. In addition, the two internal 12V 15W SATA power ports ensure the installed cards have enough power (up to 40W per card) at their disposal.
  • 8K & 4K Monitor Support
    Connect a second high-resolution monitor using the DP 1.4 or Thunderbolt 3 ports at the back of the chassis. Enjoy video resolutions of up to single 8K or 5K 60Hz or dual 4K 60Hz (other video resolutions are also supported).
  • Compatibility
    The enclosure is driverless, enabling rapid deployment and is supported in macOS, Windows, and Linux. The chassis can be placed horizontally or vertically, adapting to your workspace. The toolless design and aluminum construction ensure fast card installation and longevity. Note: Some expansion cards installed in the chassis may require drivers to be installed.
StarTech.com Thunderbolt 3 PCIe Expansion Chassis, Enclosure Box W/Dual PCI-E Slots, External PCIe Slots for Laptops/Desktops/All-In-Ones, 8K/4K Output Via TB3/DP 1.4 Ports - For PCI Express Cards (2TBT3-PCIE-ENCLOSURE) - system bus extender - DP - TAA Compliant
System bus extender
Video Interfaces
DP
28.1 cm x 8.4 cm x 14.2 cm
1.6 kg
Power adapter AC 100-240 V 120 Watt Power Provided
TAA Compliant
System bus extender
28.1 cm
8.4 cm
14.2 cm
1.6 kg
Enclosure Colour
Expansion Slots
2 (total) / 2 (free) x PCI Express 3.0 x16 , 2 (total) / 2 (free) x 15-pin SATA power plug
2 x Thunderbolt 3 - 24 pin USB-C , 1 x display / video - DisplayPort - 20 pin DisplayPort
1 x Thunderbolt cable - external - 1 m
Power adapter, Thunderbolt cable (1m), foot-pad set
LED indicator, 60 mm cooling fan, 40 Gbps Thunderbolt bandwidth, Titan Ridge DSL7440 chipset, Ti TPS65983B chipset
RoHS, WEEE, DisplayPort 1.4, Thunderbolt 3
TAA Compliant
Power adapter
AC 100-240 V
Power Provided
120 Watt
Apple MacOS, Linux, Microsoft Windows
Shipping Width
35.3 cm
Shipping Depth
28.5 cm
Shipping Height
14.3 cm
Shipping Weight
3.4 kg
5 °C
65 °C
HHWZ StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £19.29
HHWZ StarTech.com PCIe Fiber Optic NIC w/ SFP+ In Stock £237.18
HHWZ StarTech.com 1 Port 2.5Gbps 2.5GBASE-T PCIe Network Card x4 PCIe In Stock £27.05
HHWZ StarTech.com 4-Port USB PCIe Card In Stock £104.51
Speed: [N/A]
Ports: 3
Price Range Ex VAT: £500 - £750
