StarTech.com Thunderbolt 3 Ethernet Adapter
Quicklinx: H789WS00 Mfr#: TB310G2
£179.53 ex VAT
£215.43 inc VAT
This Thunderbolt to Ethernet 10G adapter is a robust and durable solution for IT professionals looking to add an RJ45 port to their Thunderbolt-enabled computer. This adapter supports multi-gigabit speeds, including 10/5/2.5/1Gb/s and 100Mb/s Base-T speeds. In addition, 10GBASE-T and 5GBASE-T/2.5GBASE-T (NBASE-T) capabilities ensure compatibility with the latest network switches and access points.
  • 10GbE Network Speeds
    A Thunderbolt 3 to RJ45 is the ideal accessory for bandwidth-intensive tasks, server maintenance, high-performance storage, or streaming online content. The adapter is powered by the Marvell AQC107S, providing high-speed 10GbE speeds and supports plug-and-play in Windows and macOS for straightforward deployment.
  • Quiet and Compact Design
    This Thunderbolt 3 NIC is a portable and convenient peripheral for on-the-go users with a footprint of just 4.27x2.9x1.14in (108.5x75x29.1mm). The aluminum chassis utilizes passive cooling for noiseless operation. Activity and computer link LEDs provide status at a glance. The Thunderbolt to NIC adapter includes a certified 27.5in (70cm) Thunderbolt 3 cable, which ensures maximum performance on Thunderbolt 3 and 4 computers. This TAA-compliant Thunderbolt 3 NIC is backed for two years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com Thunderbolt 3 to Ethernet Adapter, 10GbE, Multi-Gigabit, Thunderbolt 3 to RJ45 Network Adapter, 10GBASE-T/5-2.5GBASE-T NIC, TB3/TB4 10G Network Adapter w/ TB3-Certified Cable, TB3 10GbE, Win/Mac (TB310G2) - network adapter - Thunderbolt 3 - 1/2.5/5/10GBase-T x 1
Network adapter
External
Interface (Bus) Type
Thunderbolt 3
Ports
10.8 cm 2.9 cm
500 g
Cabling Type
Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T
100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
Data Transfer Rate
40 Gbps
Jumbo frame size: 16000
Intel / Alpine Ridge / Marvell JHL6340 / AQC107S
IEEE 802.3u, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3bz
Space grey
Linux LTS versions only, Microsoft Windows 10 / 11, Ubuntu Linux 20.04 or later, Apple macOS 10.15 / 11.0 / 12.0 / 13.0
Network adapter
External
Thunderbolt 3
Ports
Wired
Cabling Type
Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
40 Gbps
Status Indicators
Link/activity, connection status
Auto-negotiation
Processor / Memory
1 x 10GBase-T - RJ-45 - female , 1 x Thunderbolt 3 - 24 pin USB-C - female
1 x Thunderbolt 3 / USB-C cable (external)
Space grey
10.8 cm
2.9 cm
500 g
35 °C
55 °C
20 - 80% (non-condensing)
Type: Network Adaptor
