StarTech.com Thunderbolt 3 Dock with USB-C (USB 3.1 Gen & Gen 2)
Quicklinx: FC0PWS00 Mfr#: TB3CDK2DPUE
For the first time, there is a plug-and-play Thunderbolt 3 docking station that intelligently adapts to your Thunderbolt 3 or USB-C (USB 3.1 Gen 1 and Gen 2) laptop offering optimal performance and compatibility. This revolutionary technology offers IT professionals the solution they need - one dock for Mac and Windows laptops that are equipped with a USB Type-C port.
With this dedicated dual DisplayPort Thunderbolt 3 dock, you can turn your TB3 or USB 3.1 (Type-C) laptop into a dual-monitor workstation, including dual 4K60Hz resolution on Thunderbolt 3 laptops.
Simply connect the dock to your laptop with the included Thunderbolt 3 cable and start working immediately. With easy plug-and-play installation, the dock is ready to go as soon as you connect it, saving you the time and hassle of installing additional drivers or software.
For more installation flexibility, you can use StarTech.com mounting brackets (SSPMSUDWM & SSPMSVESA) that are specifically designed for the docks and hubs, to mount your TB3 dock to a desk, wall, or other surface to give you the customized setup you need.
If you require more security, the built-in K-Slot uses a traditional laptop combination cable lock to ensure your dock stays put.
This universal Thunderbolt 3 dock (TB3) features plenty of USB 3.0 ports to accommodate up to five USB peripherals and includes a GbE port and audio support: 3 x USB-A Ports (including 1 x Fast-Charge Port); 2 x USB-C Ports (including 1 x Charge Port); 1 x Gigabit Ethernet Port; 1 x 3.5 mm Audio/Mic Port .
The USB-C ports and one of the USB-A ports will support up to 10Gbps (USB 3.1 Gen 2) data transfer speeds, when the host laptop supports the same.
Using a single cable, the dock powers and charges your laptop with 60W Power Delivery, using the included 135W power adapter. The USB-A and USB-C charge ports can charge your smartphone, tablet or other USB peripherals whether you're working or away from your desk, and even if you disconnect your laptop.
Note: Not all USB-C ports support the full functionality of the USB Type-C standard. Ensure that your laptop USB-C port supports DP Alt Mode and USB Power Delivery.
  • Easy to install and deploy
    Simply connect the dock to your laptop with the included Thunderbolt 3 cable and start working immediately. With easy plug-and-play installation, the dock is ready to go as soon as you connect it, saving you the time and hassle of installing additional drivers or software. For more installation flexibility, you can use StarTech.com mounting brackets that are specifically designed for StarTech.com docks and hubs, to mount your TB3 dock to a desk, wall, or other surface to give you the customized setup you need. If you require more security, the built-in K-Slot uses a traditional laptop combination cable lock to ensure your dock stays put.
  • Plenty of ports
    This universal Thunderbolt 3 dock (TB3) features plenty of USB 3.0 ports to accommodate up to five USB peripherals and includes a GbE port and audio support: 3 x USB-A Ports (including 1 x Fast-Charge), 2 x USB-C Ports (including 1 x Fast-Charge), 1 x Gigabit Ethernet Port, and 1 x 3.5 mm Audio/Mic Port. The USB-C ports and one of the USB-A ports will support up to 10Gbps (USB 3.1 Gen 2) data transfer speeds, when the host laptop supports the same.
  • Power your laptop while charging USB-C and USB-A devices
    Using a single cable, the dock powers and charges your laptop with 60W Power Delivery, using the included 135W power adapter. The USB-A and USB-C Fast-Charge ports can charge your smartphone, tablet or other USB peripherals whether you're working or away from your desk, and even if you disconnect your laptop.
StarTech.com Thunderbolt Certified 3 Docking Station w/ USB-C Compatibility, 4K60Hz DisplayPort Dual Monitor Laptop TB3 10Gbps Dock, Ethernet, 5x USB 3.0/3.1 Gen 1/2 Hub, 60W Power Delivery - Universal USB-C Dock (TB3CDK2DPUE) - docking station - USB-C 3.1 / Thunderbolt 3 - DP - 1GbE
Docking station
Docking Interface
Video Interfaces
DP
22 cm x 8 cm x 3 cm
250 g
Black, space grey
United Kingdom, Europe
Gigabit Ethernet
Power adapter AC 120/230 V 135 Watt Power Provided
3-year warranty
Docking station
22 cm
8 cm
3 cm
250 g
Enclosure Colour
Black, space grey
Video
Max Resolution Details
3840 x 2160 , 1920 x 1080 , 1920 x 1200
1 x USB 3.1 Gen 2 - 9 pin USB Type A , 2 x display / video - DisplayPort output - 20 pin DisplayPort , 2 x USB-C 3.1 Gen 2 - 24 pin USB-C , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x audio - line-out/microphone - mini-phone stereo 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x Thunderbolt cable - external - 70 cm
Security lock slot (cable lock sold separately), 1 USB 3.0 fast charging port, 1 USB-C fast charging port, 60W power delivery
Security Slot Type
Kensington security slot
FCC, RoHS, WEEE, REACH, DisplayPort 1.2a, HDCP 2.2, HDCP 1.4
Power adapter
AC 120/230 V
Power Provided
135 Watt
Apple macOS Sierra 10.12, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Windows 8 / 10 / 11, Apple macOS Ventura 13.0
Limited warranty - 3 years
Shipping Width
27.2 cm
Shipping Depth
16 cm
Shipping Height
11 cm
FC0P StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.60
FC0P StarTech.com DisplayPort to DVI Active Adapter In Stock £21.34
FC0P StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £41.39
FC0P StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £18.76
FC0P StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £21.80
FC0P StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £21.76
FC0P StarTech.com 0.8m / 2.7ft Thunderbolt 3 to Thunderbolt 3 Cable - 40Gbps In Stock £32.51
FC0P StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla In Stock £9.29
