StarTech.com Thunderbolt 3 Dock/USB-C Dock - Dual 4K DP/HDMI, 1x8K - 96W
Quicklinx: G6JCWS00 Mfr#: TB3CDK2DHUE
Device Type: Laptop, Macbook, Monitor, Ultrabook
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black/Grey
More than 50 In Stock
£145.29 ex VAT
£174.34 inc VAT
Dual DP 4K 60Hz or Dual HDMI 2.0 Monitors macOS & Windows | 5x USB 3.0 Ports 96W PD 0.8 m Cable. A high-performance Thunderbolt 3 Certified docking station with USB Type-C compatibility featuring dual monitor 4K 60Hz DSC support from either Dual or dual HDMI 2.0 video outputs, 96W Power Delivery (100W peak power), 5x USB 3.2 Hub with 2x BC 1.2 fast charging ports, gigabit Ethernet & headset ports.
Flexible Dual Display Outputs
This universal docking station features both dual DisplayPort 1.4 (Single 8K30 on HBR3 host) and dual HDMI video outputs that can be configured in three different ways:
DisplayPort + DisplayPort
HDMI + HDMI
DisplayPort + HDMI
Resolutions and video outputs are host-dependent.
Host Output
DCS Status
Single Video
Dual Video
Thunderbolt with DP 1.4 (nVidia Graphics)
Off
8K (7680 x 4320) @ 30Hz (DP Only)
n/a
Off
n/a
2x 4K (3840x2160) @60Hz
On
4K (3840x2160) @144Hz
n/a
On
n/a
Thunderbolt with DP 1.4 (Intel Graphics)
n/a
5K (5120x2880) @60Hz (DP Only)
n/a
n/a
n/a
Thunderbolt with DP 1.2
n/a
n/a
n/a
n/a
USB Type-C DP Alternate Mode DP 1.4
Off
4K (3840x2160) @30Hz
n/a
Off
n/a
2x QHD (2560x1440)
On
n/a
On
n/a
USB Type-C DP Alternate Mode DP 1.2
n/a
n/a
n/a
n/a
2x 1080p (1920x1080) @ 60Hz
More Downstream USB Ports
Featuring an integrated USB 3.2 hub, this docking station has 5 downstream USB ports:
Front Facing:
1x USB 3.2 Gen 2 Type-C (10 Gbps) with 15W (3A, 5V) Charging
1x USB 3.2 Gen 2 Type-A (10 Gbps) with B.C. 1.2 Fast-Charging
Back Facing:
2x USB 3.2 Gen 1 Type-A (5 Gbps)
Easy to Set Up & Manage
This universal Thunderbolt 3 / USB-C Dock has an automatic driver setup and includes a longer 0.8 meter (2.6 ft) Thunderbolt 3 host cable, front-facing TB3/USB-C host port, front-facing LED indicator, mounting holes for the optional bracket, k-slot for security lock & MAC address changer utility.
Connected Device Transparency with the StarTech.com MAC Address Changer Utility
The TB3CDK2DHUE includes a free Windows application that enables you to better manage your enterprise network security. When you connect to your network through the ethernet port of the dock, the computer's MAC address is typically not broadcast to the network, as your network only sees the MAC address of the docking station. However, the StarTech.com MAC Address Changer or Cloning software enables the USB-C dock to use MAC address spoofing of the connected Windows laptop rather than the MAC address of the dock itself. This ensures your network administrators have full visibility of each device on the network and can monitor and limit activity accordingly. To request access to our MAC Address Changer utility, please contact our Technical Support Department by phone, live chat, or e-mail.
TB3CDK2DHUE is backed by a StarTech.com three-year warranty and free lifetime technical support.
  • Flexible Dual Display Outputs
  • More Downstream USB Ports
    Featuring an integrated USB 3.2 hub, this docking station has 5 downstream USB ports: Front Facing:
  • Easy to Set Up & Manage
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com Thunderbolt 3 Dock with USB-C Host Compatibility, Dual 4K 60Hz DisplayPort 1.4 or Dual HDMI 2.0 Monitors, Single 8K, TB3/USB-C Laptop Docking Station, 96W PD, 5x USB, 10Gbps - 96W Power Delivery (TB3CDK2DHUE) - docking station - USB-C 3.2 Gen 2 / Thunderbolt 3 - 2 x HDMI, 2 x DP - 1GbE
Docking station
Docking Interface
Video Interfaces
2 x HDMI, 2 x DP
22 cm x 8 cm x 3 cm
250 g
Gigabit Ethernet
Power adapter AC 120/230 V
3-year warranty
Docking station
22 cm
8 cm
3 cm
250 g
Video
Max Resolution Details
7680 x 4320 - 30 Hz , 3840 x 2160 - 60 Hz (Dual Display) , 3840 x 2160 - 144 Hz (DisplayPort 1.4 only) , 5120 x 2880 - 60 Hz (DisplayPort 1.4 only) , 3840 x 2160 - 60 Hz (DisplayPort 1.4 over USB-C) , 5120 x 2880 - 60 Hz (DisplayPort 1.4 over USB-C) , 3840 x 2160 - 30 Hz (DisplayPort 1.2 over USB-C) , 2560 x 1440 (Dual Display)
Battery Charging 1.2, USB 3.2 Gen 2, USB 3.2 Gen 1, USB 3.0
1 x USB-C 3.2 Gen 2 / Thunderbolt 3 with Power Delivery 100W (96W sustained) - 24 pin USB-C , 2 x display / video - DisplayPort - 20 pin DisplayPort , 2 x display / video - HDMI - 19 pin HDMI Type A , 1 x audio - headphones/microphone - mini-phone stereo 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB 3.2 Gen 2 with Fast Charging - 9 pin USB Type A , 2 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 2 with Fast Charging - 24 pin USB-C , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C
1 x Thunderbolt 3 / USB-C cable - external - 80 cm
Security lock slot (cable lock sold separately), 96W power delivery
Security Slot Type
Kensington security slot
DisplayPort 1.4, RoHS, FCC, DSC
Power adapter
AC 120/230 V
Windows 8 / 10 / 11, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Ubuntu 18.04, Ubuntu 20.04
Limited warranty - 3 years
Shipping Width
30.5 cm
Shipping Depth
16 cm
Shipping Height
11 cm
Shipping Weight
1.1 kg
35 °C
G6JC StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.60
G6JC StarTech.com DisplayPort to DVI Active Adapter In Stock £21.34
G6JC StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £41.39
G6JC StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £21.76
G6JC StarTech.com VESA Mounting Bracket In Stock £7.75
Device Type: Laptop
Device Type: Macbook
Device Type: Monitor
Device Type: Ultrabook
Colour: Black/Grey
