StarTech.com Thunderbolt 3 Dock Mac & Win
Quicklinx: CRYNWS00 Mfr#: TB3DKDPMAWUE
With a single cable, connect your Thunderbolt 3 equipped MacBook or laptop to two 4K monitors and multiple peripherals at 40Gbps. This cost-effective Thunderbolt 3 dock (without Power Delivery) supports your Thunderbolt 3 port equipped MacBook Pro or Windows based laptop. Plus, the dock supports dual monitors, so you can easily connect two 4K Ultra HD (up to 60Hz) displays (one DisplayPort and one Thunderbolt 3 USB-C port), or a single Thunderbolt 3 display (60Hz).
Merging performance with simplicity, this high-quality dock is a single-cable solution that caters to creative professionals such as video producers, graphic and web designers, engineers, architects, and many more.
You can quickly integrate the dock into your workspace and boost your productivity. With up to 40Gbps of throughput, you can add extra displays to your laptop, access files faster, and reduce waiting, so you can accomplish more in the same amount of time.
Thunderbolt 3 is the fastest connection available, and it supports multiple video channels and data, without impacting system performance. It's easy to access and edit large uncompressed files such as videos and images on the fly.
If you need a larger, higher-resolution viewing area, this dock can help. You can connect two 4K Ultra HD displays, so it's perfect for anyone working with high-bandwidth or graphics-intensive content.
The Thunderbolt 3 dock supports two 4K (3840 x 2160p) monitors at up to 60Hz through the DisplayPort and Thunderbolt 3 USB-C port (USB-C video adapter might be required). For dual monitors, simply connect your DP monitor, and a second monitor through the dock's extra Thunderbolt 3 port using an adapter such as the USB-C to DisplayPort Adapter Cable (CDP2DPMM1MB - sold separately) or using a USB-C based monitor. The Thunderbolt dock will also work with legacy displays such as VGA monitors when coupled with a USB-C to VGA adapter.
With support for two 4K monitors, the Thunderbolt dock makes it easier to multitask when you're working with high-definition video or other complex work.
For advanced 5K resolutions requirements, this dock supports a single 5K display when you connect your monitor to one of the Thunderbolt 3 ports, delivering 5120 x 2880p resolutions at up to 60Hz.
Using the single Thunderbolt 3 cable (included) and a single port on your laptop, you can transform your macOS Sierra (or later) or Windows 7 (or later) laptop into a full-size workstation with access to new and legacy technologies through a number of different port types. The dock is ideal for virtually all Thunderbolt 3 equipped laptops such as the Dell XPS 13, and the Apple MacBook Pro (2016).
The Thunderbolt 3 docking station features two Thunderbolt 3 USB-C ports for connecting to Thunderbolt devices and other peripherals that use the USB-C connector, as well as DisplayPort video output.
You can keep your mobile device charged and ready to go using the dock's convenient, always-on USB fast-charge and sync port which supports USB Battery Charging Specification 1.2. The Thunderbolt 3 dock offers a variety of other connections that are often missing from port-limited laptops, such as an extra USB-C port (5Gbps - data only), and a Gigabit Ethernet port.
With three USB 3.0 ports in total, you have plenty of ports to connect modern and legacy devices. (USB 3.0 is also known as USB 3.1 Gen 1.) Now, you can rest assured knowing you're ready for the current and next generation of universal connectivity.
The rear-panel DP and USB-C ports can be used with dual monitors that support lower resolutions, such as 4K at 30Hz or 1080p. StarTech.com offers a variety of USB-C video adapters, such as USB-C to HDMI and USB-C to VGA, which lets you connect a mixture of modern and legacy displays to the docking station.
  • Finish your work faster with Thunderbolt 3
  • Easy installation and deployment
    Simply connect the TB3 dock to your laptop with the included TB3 cable and start working immediately. No time-consuming driver installations are required.
  • Multitask at the highest resolution
    The Thunderbolt 3 dock supports two 4K (3840 x 2160p or 4096 x 2160p) monitors through the DisplayPort and Thunderbolt 3 USB-C port (a USB-C video adapter might be required).
  • Connect your peripherals using only a single cable
Startech Thunderbolt 3 Dock - Dual 4K - Mac and Windows - docking station - Thunderbolt 3 - DP - 1GbE
Docking station
Docking Interface
Thunderbolt 3
Video Interfaces
DP
22 cm x 8 cm x 2.7 cm
442 g
Black and grey
United Kingdom, Europe
Gigabit Ethernet
Power adapter AC 120/230 V
3-year warranty
Docking station
22 cm
8 cm
2.7 cm
442 g
Enclosure Colour
Black and grey
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1
2 x Thunderbolt 3 - 24 pin USB-C , 1 x display / video - DisplayPort output - 20 pin DisplayPort , 1 x USB-C - 24 pin USB-C , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x audio - line-in/microphone - mini-phone 3.5 mm , 1 x audio - line-out/headphones - mini-phone stereo 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x Thunderbolt cable - external - 52 cm
Dual display support, UASP transfer protocol, 1 USB 3.0 fast charging port, full duplex support
FCC, RoHS, USB Battery Charging Specification Rev. 1.2
Power adapter
AC 120/230 V
Apple macOS 10.12 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
5 °C
CRYN StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.80
CRYN StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.22
CRYN StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £14.95
CRYN StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.77
CRYN StarTech.com DisplayPort to DVI Active Adapter In Stock £20.86
CRYN StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £18.76
CRYN StarTech.com 3ft DP to HDMI cable - 4K In Stock £13.67
CRYN StarTech.com DP to VGA Adapter with Audio In Stock £19.30
CRYN StarTech.com USB-C to VGA Adapter In Stock £21.67
CRYN StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £29.91
CRYN StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £12.99
CRYN StarTech.com USB-C to HDMI Adapter In Stock £15.93
CRYN StarTech.com USB-C to HDMI Adapter In Stock £15.52
CRYN StarTech.com Thunderbolt 3 to Thunderbolt In Stock £27.51
CRYN StarTech.com 0.5m Thunderbolt 3 Cable In Stock £29.10
CRYN StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £6.73
CRYN StarTech.com 6ft USB-C to DisplayPort Cable In Stock £18.05
CRYN StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.72
