Connect your Thunderbolt 3 equipped MacBook or laptop to multiple monitor combinations (DP, HDMI, VGA), GbE and two USB 3.0 ports, plus power and charge as you work. Create a powerful and flexible workstation with this Thunderbolt 3 dock. With dedicated dual video output, you can connect your Thunderbolt 3 equipped MacBook Pro or Windows laptop to two 4K monitors, through a single Thunderbolt 3 cable. Connect your peripherals with two USB 3.0 ports, and power and charge your laptop with 85W Power Delivery.
Great for editing 4K video or other Ultra HD tasks, this Thunderbolt 3 docking station supports 40Gbps speeds and 4K resolution at 60Hz on two monitors. Run resource-demanding applications on two displays without draining system resources.
Enjoy ultimate flexibility in setting up your workstation, with monitor options including DisplayPort (DP), HDMI and VGA. The dock offers many dedicated dual-video options: 2x DisplayPort (4096 x 2160p @ 60Hz); 1x DisplayPort + 1 HDMI (4096 x 2160p @ 60Hz); 1x VGA (1920 x 1200p @ 60Hz) + 1x DisplayPort (4096 x 2160p @ 60Hz); 1x VGA (1920 x 1200p @ 60Hz) + 1x HDMI (4096 x 2160p @ 60Hz).
Through a single 120W power adapter, the Thunderbolt 3 docking station simultaneously powers and charges your laptop and your attached peripherals while it's docked. It provides up to 85W of charging power through Power Delivery.
Harness the reliability of a wired network connection with the Gigabit Ethernet port (supporting PXE Boot and Wake-on-LAN). Connect your USB devices with two USB 3.0 Type-A ports.
The TB3DK2DHVUE is fully Thunderbolt 3 Certified.
Easy Installation & Deployment
Simply connect the?TB3 dock?to your laptop with included TB3 cable and start working immediately. No?time-consuming driver installations are required. -
Speed & Flexibility with 3 Monitor Options
Great for editing 4K video or other Ultra HD tasks, this Thunderbolt 3 docking station supports 40Gbps speeds and 4K resolution at 60Hz on two monitors. Enjoy ultimate flexibility in setting up your workstation, with monitor options including DisplayPort (DP), HDMI and VGA. The dock offers many dedicated dual-video options: 2x DisplayPort (4096 x 2160p @ 60Hz) 1x DisplayPort + 1 HDMI (4096 x 2160p @ 60Hz) 1x VGA (1920 x 1200p @ 60Hz) + 1x DisplayPort (4096 x 2160p @ 60Hz) 1x VGA (1920 x 1200p @ 60Hz) + 1x HDMI (4096 x 2160p @ 60Hz) -
The Ports You Need Most
Harness the reliability and speed of a wired network connection with the Gigabit Ethernet port (supporting PXE Boot and Wake-on-LAN). Connect your USB devices with two USB 3.0 Type-A ports. -
Power & Charge with 85W Power Delivery
Through a single 120W power adapter, the Thunderbolt 3 docking station simultaneously powers and charges your laptop and your attached peripherals while it's docked. It provides up to 85W of charging power through Power Delivery. The TB3DK2DHVUE is fully Thunderbolt 3 Certified and backed by a StarTech.com 3-year warranty and free lifetime technical support.
- StarTech.com Thunderbolt 3 Dock, Dual 4K 60Hz Monitor TB3 Docking Station with DisplayPort, HDMI & 1080p VGA, 85W Power Delivery & Charging, Gigabit Ethernet, Universal Thunderbolt 3 Dock - TB3 Dock w/ 85W PD (TB3DK2DHVUE) - docking station - Thunderbolt 3 - VGA, HDMI, 2 x DP - GigE
- Product Type
- Docking station
- Docking Interface
- Thunderbolt 3
- Video Interfaces
- VGA, HDMI, 2 x DP
- 5.86 cm x 19.6 cm x 2.35 cm
- 340 g
- Grey
- Localisation
- United Kingdom, Europe
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 120/230 V Power Provided
- 3-year warranty
- Product Type
- Docking station
- 5.86 cm
- 19.6 cm
- 2.35 cm
- 340 g
- Enclosure Colour
- Grey
- Localisation
- Data Link Protocol
- Gigabit Ethernet
- 1 x Thunderbolt 3 - 24 pin USB-C , 2 x display / video - DisplayPort output - 20 pin DisplayPort , 1 x display / video - HDMI output - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
- Cables Included
- 1 x Thunderbolt cable - external - 50 m , 2 x power cable
- Dual display support, UASP transfer protocol, 1 USB 3.0 fast charging port, Preboot Execution Environment (PXE) support, full duplex support, 4K Ultra HD, 85W power delivery, auto MDIX support
- FCC, RoHS, WEEE
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V
- OS Required
- Apple macOS 10.12 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- Shipping Weight
- 1.3 kg
- 0 °C
- 40 °C
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £15.80 |
StarTech.com DisplayPort to DVI Active Adapter | In Stock | £22.91 |
StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black | In Stock | £21.79 |
StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black | In Stock | £23.85 |
StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter | In Stock | £21.47 |
StarTech.com DP to VGA Adapter with Audio | In Stock | £23.64 |
StarTech.com 0.5m Thunderbolt 3 Cable | In Stock | £19.39 |
StarTech.com DisplayPort to HDMI - 4K 60Hz | In Stock | £23.58 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £12.26 |
