StarTech.com Thunderbolt 3 Dock - Dual-4K
Quicklinx: D9KQWS00 Mfr#: TB3DOCK2DPPU
This universal Thunderbolt 3 dock lets you power through your work day. The dock features 85W power delivery to power and charge your laptop, and multiple ports to connect your peripherals, with USB 3.0 ports and an SD card reader. With its aluminum design, it's the perfect accessory for your Thunderbolt 3 equipped laptop.
  • Create a Dual-4K 60Hz Workstation
    This dual-monitor docking station supports 40Gbps speeds and 4K (4096 x 2160) resolution at 60Hz on two monitors, enabling resource-demanding applications on independent displays without draining system resources. The TB3 dock can support 5K (5120 x 2880) resolutions @ 60Hz on a single display. Connect your laptop to: • 1 x 4K monitor via the DP Port • 1 x 4K monitor via the TB3 USB-C Port (1.8 m cable included) OR • 1 x 5K monitor via the DP and TB3 USB-C ports
  • Easy Installation & Deployment
    Simply connect the TB3 dock to your laptop with the included TB3 cable and start working immediately. No time-consuming driver installations are required. Set up a second monitor using the included USB-C to DisplayPort cable adapter, eliminating the need for extra adapters.
  • Plenty of Ports Including SD Card Reader
    The TB3 docking station offers six USB 3.0 ports, including a Fast-Charge port and USB-C port, an GbE port and audio/microphone port. The built-in SD card reader adds storage not usually available on most docking stations.
  • 85W Power Delivery
    Using a single cable, the universal laptop docking station provides up to 85W of Power Delivery to power and charge your laptop, and power your peripherals with its 180W power adapter.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com Thunderbolt 3 Dock, Dual Monitor 4K 60Hz TB3 Laptop Docking Station with DisplayPort, 85W Power Delivery Charging, 6-Port USB 3.0 Hub, SD 4.0 Reader, GbE, Audio, Windows & Mac - 85W PD TB3 Dock (TB3DOCK2DPPU) - docking station - Thunderbolt 3 - DP - 1GbE
Docking station
Docking Interface
Thunderbolt 3
Video Interfaces
DP
22.2 cm x 8.7 cm x 3.4 cm
492 g
Space grey
United Kingdom, Europe
Gigabit Ethernet
Power adapter AC 100 - 240 V 180 Watt Power Provided
3-year warranty
Docking station
22.2 cm
8.7 cm
3.4 cm
492 g
Enclosure Colour
Space grey
Gigabit Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
2 x Thunderbolt 3 - 24 pin USB-C , 1 x display / video - DisplayPort output - 20 pin DisplayPort , 1 x USB-C - 24 pin USB-C , 1 x SuperSpeed USB 3.0 with Fast Charging - 9 pin USB Type A , 4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x audio - line-out/headphones - mini-phone stereo 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
Compatible Slots
SD / MMC Memory Card
1 x DisplayPort / USB-C cable - external - 1.8 m , 1 x Thunderbolt cable - external , 2 x power cable
Dual display support, UASP transfer protocol, Preboot Execution Environment (PXE) support, full duplex support, 4K Ultra HD, 5K Ultra HD
FCC, RoHS, USB Battery Charging Specification Rev. 1.2
Power adapter
AC 100 - 240 V
Power Provided
180 Watt
Apple macOS 10.12 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Windows 8 / 8.1 / 10 / 11, Apple macOS 13.0
Limited warranty - 3 years
Shipping Weight
1.5 kg
D9KQ StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.94
D9KQ StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.60
D9KQ StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £14.91
D9KQ StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £21.80
D9KQ StarTech.com USB-C to HDMI Adapter In Stock £15.52
D9KQ StarTech.com Thunderbolt 3 to Thunderbolt In Stock £27.51
D9KQ StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £7.64
D9KQ StarTech.com Thunderbolt 3 PCIe Enclosure In Stock £233.89
