The Thunderbolt 3 to 1394 FireWire adapter brings your high-powered FireWire peripheral devices to life through your Thunderbolt 3 computer. The Thunderbolt 3 to 1394 FireWire adapter connects your FireWire peripherals to your Thunderbolt 3 computer. This adapter combines StarTech.com's Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) and 1394 FireWire adapter card (PEX1394B3). The chassis uses Thunderbolt 3 technology, the fastest connection available, supporting your FireWire devices, plus one DisplayPort output and one additional Thunderbolt 3 port.
Use your legacy FireWire devices with your next-generation Thunderbolt 3 computer, without having to pay for upgraded peripherals.
Thunderbolt 3 is the fastest connection available. By avoiding performance bottlenecks, you can accomplish more in the same amount of time. With 40Gbps of throughput and support for other high-performance PCIe cards, you can swap the card in and out, to add the peripherals you need connected to a Thunderbolt 3 desktop or laptop computer.
Both hot-swap and backward compatible, you can assemble and connect this adapter in minutes. Install the PCIe card using only a Phillips type screwdriver, then plug and play with automatic driver installation.
Save on upgrade costs
Use your legacy FireWire devices with your Thunderbolt 3 computer, without having to pay for upgraded peripherals. -
Increase productivity with Thunderbolt 3
Thunderbolt 3 is a fast connection. By avoiding performance bottlenecks, you can accomplish more in the same amount of time. -
Install with ease
- StarTech.com Thunderbolt 3 to Firewire Adapter - 1394 FireWire - External PCIe Enclosure / Chassis plus Card - with DisplayPort Monitor Port (BNDTB1394B3) - FireWire adapter - PCIe - FireWire 800 x 2 + FireWire x 1
- FireWire adapter
- Form Factor
- Plug-in card
- Bundled with
- Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) with DisplayPort
- Interface (Bus) Type
- PCI Express x1
- Ports
- Data Link Protocol
- Firewire
- Data Transfer Rate
- 3.94 Gbps
- 2-year warranty
- FireWire adapter
- Form Factor
- Plug-in card
- Bundled with
- PCI Express x1
- Ports
- Connectivity Technology
- Wired
- IEEE 1394 (FireWire)
- 3.94 Gbps
- 2 x FireWire 800 - 9 pin FireWire 800 , 1 x FireWire - 6 PIN FireWire
- Limited warranty - 2 years
- 0 °C
- 70 °C
StarTech.com 3 Port 2b 1a 1394 PCI Express FireWire Card Adapter | In Stock | £49.12 |
StarTech.com PCI Express X1 to X16 Low Profile Slot Extension Adapter | In Stock | £19.72 |
StarTech.com 10 ft 1394b Firewire 800 Cable 9-9 M/M | In Stock | £11.76 |
StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP | In Stock | £34.48 |
StarTech.com 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485 | In Stock | £110.54 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels | In Stock | £46.45 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels | In Stock | £80.54 |
StarTech.com USB-C to VGA Adapter | In Stock | £21.67 |
StarTech.com 4-Port Gigabit NIC - PCIe | In Stock | £151.83 |
StarTech.com 2-Port 10G Fiber NIC-Open SFP+ | In Stock | £295.64 |
StarTech.com 2-Port PCI Express 10GBase-T Ethernet Network Card | In Stock | £289.51 |
StarTech.com 2x M.2 SSD Controller - PCIe | In Stock | £21.26 |
StarTech.com USB-C to HDMI Adapter | In Stock | £15.52 |
StarTech.com PCIe HDMI & VGA Capture Card | In Stock | £78.45 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £18.76 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £22.59 |
StarTech.com U.2 to PCIe Adapter -SFF-8639 | In Stock | £25.91 |
