StarTech.com Thunderbold 3 FireWire Adapter w/ Chassis
Quicklinx: DXG4WS00 Mfr#: BNDTB1394B3
The Thunderbolt 3 to 1394 FireWire adapter brings your high-powered FireWire peripheral devices to life through your Thunderbolt 3 computer. The Thunderbolt 3 to 1394 FireWire adapter connects your FireWire peripherals to your Thunderbolt 3 computer. This adapter combines StarTech.com's Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) and 1394 FireWire adapter card (PEX1394B3). The chassis uses Thunderbolt 3 technology, the fastest connection available, supporting your FireWire devices, plus one DisplayPort output and one additional Thunderbolt 3 port.
Use your legacy FireWire devices with your next-generation Thunderbolt 3 computer, without having to pay for upgraded peripherals.
Thunderbolt 3 is the fastest connection available. By avoiding performance bottlenecks, you can accomplish more in the same amount of time. With 40Gbps of throughput and support for other high-performance PCIe cards, you can swap the card in and out, to add the peripherals you need connected to a Thunderbolt 3 desktop or laptop computer.
Both hot-swap and backward compatible, you can assemble and connect this adapter in minutes. Install the PCIe card using only a Phillips type screwdriver, then plug and play with automatic driver installation.
  • Save on upgrade costs
    Use your legacy FireWire devices with your Thunderbolt 3 computer, without having to pay for upgraded peripherals.
  • Increase productivity with Thunderbolt 3
    Thunderbolt 3 is a fast connection. By avoiding performance bottlenecks, you can accomplish more in the same amount of time.
  • Install with ease
StarTech.com Thunderbolt 3 to Firewire Adapter - 1394 FireWire - External PCIe Enclosure / Chassis plus Card - with DisplayPort Monitor Port (BNDTB1394B3) - FireWire adapter - PCIe - FireWire 800 x 2 + FireWire x 1
FireWire adapter
Plug-in card
Bundled with
Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) with DisplayPort
Interface (Bus) Type
PCI Express x1
Ports
Firewire
Data Transfer Rate
3.94 Gbps
FireWire adapter
Plug-in card
Bundled with
PCI Express x1
Ports
Wired
IEEE 1394 (FireWire)
Data Transfer Rate
3.94 Gbps
2 x FireWire 800 - 9 pin FireWire 800 , 1 x FireWire - 6 PIN FireWire
70 °C
DXG4 StarTech.com 3 Port 2b 1a 1394 PCI Express FireWire Card Adapter In Stock £49.12
DXG4 StarTech.com PCI Express X1 to X16 Low Profile Slot Extension Adapter In Stock £19.72
DXG4 StarTech.com 10 ft 1394b Firewire 800 Cable 9-9 M/M In Stock £11.76
DXG4 StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.48
DXG4 StarTech.com 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485 In Stock £110.54
DXG4 StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels In Stock £46.45
DXG4 StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £80.54
DXG4 StarTech.com USB-C to VGA Adapter In Stock £22.16
DXG4 StarTech.com 4-Port Gigabit NIC - PCIe In Stock £151.83
DXG4 StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £295.64
DXG4 StarTech.com 2x M.2 SSD Controller - PCIe In Stock £21.26
DXG4 StarTech.com USB-C to HDMI Adapter In Stock £15.52
DXG4 StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.76
DXG4 StarTech.com USB-C to DisplayPort Adapter In Stock £22.59
DXG4 StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £24.76
