StarTech.com Thermal Paste, 5-Pack
Quicklinx: GTC0WS00 Mfr#: SILV5-THERMAL-PASTE
£14.62 ex VAT
£17.54 inc VAT
This 5-Pack of thermal paste works with a heat sink to improve heat dissipation from integrated circuits (ICs), like CPUs, GPUs and other computer chips. The thermal paste features CE and RoHS certifications so you can rest assured it's safe for its intended use.
  • High-Performance Thermal Paste
    The thermal paste, also known as silver grease, is a metal based (metal oxide) compound that contains 50% silicone, 30% carbon and 20% metal oxide to offer better thermal conductivity than standard heat transfer pastes with negligible electrical conductivity. The thermal paste/glue is suitable for operation in temperatures of -22°F to 365°F (-30°C to 180°C) with thermal conductivity of 3.07 W/m-K at 25 °C or greater. This performance makes the compound ideal for servicing & maintaining workstations, desktop computers and servers.
  • Conveniently Sized 1.5g Tubes
    Each tube included in this five pack contains 1.5g of paste, sufficient for 4 to 6 applications, for 20 to 30 applications in total. Each unit is packaged in a syringe for easy application, that's re-sealable to prevent the product from drying between use. Plus, five included units make it ideal for distribution to different workstations throughout the work place. SILV5-THERMAL-PASTE is backed by a StarTech.com 2-year warranty, including free lifetime 24/5 multi-lingual, North American based, technical assistance.
StarTech.com Thermal Paste, High Performance Thermal Paste, Pack of 5 Re-sealable Syringes (1.5g / each), Metal Oxide Heat Sink Compound, CPU Thermal Paste, Thermal Glue, RoHS / CE - GPU Grease - thermal paste - high performance
Thermal paste - high performance
Packaged Quantity
5 (specifications are for single item)
Product Material
Silicone, carbon, metal oxide
1.5 g
Resealable
Packaged Quantity
Product Material
1.5 g
2 cm x 6.7 cm x 2 cm / 4 g
Thermal Conductivity
3.07 W/mK
Resealable
RoHS
Limited warranty: - 2 years
-30 °C
180 °C
GTC0 StarTech.com 1.5g Metal Oxide Thermal CPU Paste Compound Tube for Heatsink In Stock £4.31
