StarTech.com Tether Cables - 20 Pack - Steel
Quicklinx: HVFCWS00 Mfr#: CONNLOCKPK20
16 In Stock
£39.98 ex VAT
£47.97 inc VAT
Universal Cable and Adapter Tethers Includes Heat Shrink Covers. Secure cables and dongle adapters in boardrooms, workstations and other areas to help prevent against costly theft or accidental loss. These steel security tether cables provide a measure of physical security, by letting you attach your cables and adapters to each other.
Protect your Investment
The 20-pack of universal cable tethers give you an easy and cost-effective way to minimize the need to constantly replace cables in lobbies, public areas, work and meeting areas. They provide a measure of anti-theft by securing your cables and adapters, while also keeping cables organized by making sure you always have the right adapter or cable in the right place.
The Strength of Steel
The cable and adapter tethers are made of a thin durable steel cable with a PVC coating, providing an effective theft deterrent.
Fast and Easy Installation
The flexible steel security cable is easy to wrap around your cables or adapters, and secure in place with the aluminum ferrules, using a standard crimping tool (not included).  For versatile use, you can cut the 11.8" (300 mm) cable tethers to length, using wire cutters (not included). The steel tether does not restrict the space requirements or usage of the cable or adapter.
Attractive Design
As an option, you can cover the aluminum ferrules with the black heat shrink tubing (included).
The TAA compliant CONNLOCKPK20 is backed by a StarTech.com 5-year warranty and free lifetime technical support.
  • The strength of steel
  • Fast and easy installation
StarTech.com 20-Pack Security Cable Tethers for Adapters & Dongles, Universal Cable Adapter Tether, Tether Cables, Adjustable Length Anti-Theft Cable Tether Lock Kit, Steel Cable Tether - Dongle Cable Tether (CONNLOCKPK20) - security cable - TAA Compliant
Security cable
Package Content
40 heat shrink tubings, 40 x aluminium ferrules, 20 steel cable tethers
Silver
Product Material
Steel
Length
30 cm
TAA Compliant
5-year warranty
Security cable
Product Material
Steel
Package Content
Length
30 cm
Silver
RoHS, REACH
TAA Compliant
Limited warranty: - 5 years
